关于全志A733 android 15适配ec20和ec25
请教一下关于在Android 15上需要如何适配移远的模块呢,是否还是采用之前的ril库的方式,还是aidl的方式呢,有关于这方面的资料么?
支持Android15.
AIDL的库还没验证过,目前在Android15 已经验证的还是基于IRadio1.5的库,Quectel_Android_RIL_Driver_ndk_V3.7.0.zip
你好,能把这个最新的库文件发到我的邮箱为liufeng@szbaijie.cn
试下 Quectel_Android_RIL_Driver_radio1.5_V3.7.zip
Hi Team,
We are currently integrating the RIL library for the Quectel EM06 LTE module on our i.MX95 (Android 15) platform.
So far, we have tested the following RIL packages, but without success:
Quectel_Android_RIL_Driver_V4.0.8_aidl_20241113_01.zip
The logs corresponding to these package tests are attached for your reference.
Could you please share the verified/validated RIL libraries for Android 15 for EM06, or any recommended master RIL version that is known to work with Android 15?
Your support on this integration would be greatly appreciated.
Thanks & Regards
Seems that you already try it in the English Forum.
For Android 15 we would like try the AIDL or the HIDL 1.5.
I not able to get run it on Android 15 ,Can u share any validated librarirs for Android 15
Please check it. @Maruti_Naik
您好,问一下ec800能支持安卓15吗?有移植文档吗
您好,问一下全志安卓15驱动ec800的,没有RILJ打印信息是怎么回事呀
您好,如果没有看到RILJ,需要是否没有添加Telephony 有关的apk。
