在Jeston Nano平台适配RM500U-CN,网络连接失败
如题,我尝试了把它在我的台式机上,操作系统为ubuntu 20.4,工作正常,我认为这说明我的AT指令配置是没有问题的?
但是在Jeston Nano平台上电时,dmesg会打印:
[ 1032.507694] usb 2-1.2: new SuperSpeed USB device number 5 using tegra-xusb
[ 1032.528696] usb 2-1.2: New USB device found, idVendor=2c7c, idProduct=0900
[ 1032.528702] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1032.528706] usb 2-1.2: Product: RM500U-CN
[ 1032.528709] usb 2-1.2: Manufacturer: Quectel
[ 1032.528712] usb 2-1.2: SerialNumber: 0123456789ABCDEF
[ 1032.531541] cdc_ether 2-1.2:1.0 usb0: register ‘cdc_ether’ at usb-70090000.xusb-1.2, CDC Ethernet Device, fe:77:bb:29:89:99
[ 1032.535633] option 2-1.2:1.2: GSM modem (1-port) converter detected
[ 1032.535951] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB0
[ 1032.536183] option 2-1.2:1.3: GSM modem (1-port) converter detected
[ 1032.536354] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB1
[ 1032.536565] option 2-1.2:1.4: GSM modem (1-port) converter detected
[ 1032.536741] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 1032.537127] option 2-1.2:1.5: GSM modem (1-port) converter detected
[ 1032.537440] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 1032.537693] option 2-1.2:1.6: GSM modem (1-port) converter detected
[ 1032.537872] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB4
[ 1032.753946] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 1032.804344] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 1048.521426] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 1098.177053] cdc_ether 2-1.2:1.0 usb0: kevent 12 may have been dropped
[ 1098.184254] cdc_ether 2-1.2:1.0 usb0: kevent 12 may have been dropped
另外AT端打印:
AT^S
RDY
+QUSIM: 1
+CPIN: READY
+QIND: PB DONE
AT^SQPORT?
+CME ERROR: 4
+CFUN: 1
+QIND: SMS DONE
AT
+QNETDEVSTATUS: 1,1,“IPV4V6”,0
AT
AT+CGMI
AT+GMIAT+CGMM
RM500U-CN
AT+GMM
AT%IPSYS?
+CME ERROR: 4
AT%IPSYS?
+CME ERROR: 4
AT%IPSYS?
+CME ERROR: 4
ATE0
+CME ERROR: 4
+GCAP: +GSM
RM500U-CN
Revision: RM500UCNAAR01A07M2G
+CPIN: READY
RM500U-CN
打印的同时,ifconfig会有如下变化:
mr123@mr123-emmc3:~$ ifconfig usb0
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet6 fe80::6cc:e4f2:4575:8e23 prefixlen 64 scopeid 0x20
ether fe:77:bb:29:89:99 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 2 bytes 172 (172.0 B)
TX packets 2 bytes 432 (432.0 B)
inet 100.95.21.59 netmask 255.0.0.0 broadcast 100.255.255.255
RX packets 8 bytes 1624 (1.6 KB)
TX packets 19 bytes 2747 (2.7 KB)
inet6 240e:473:c30:a205:5538:e80c:12f1:9846 prefixlen 64 scopeid 0x0
inet6 240e:473:c30:a205:3c16:9491:e105:3772 prefixlen 64 scopeid 0x0
RX packets 15 bytes 2322 (2.3 KB)
TX packets 41 bytes 5815 (5.8 KB)
RX packets 22 bytes 3292 (3.2 KB)
TX packets 90 bytes 13656 (13.6 KB)
我希望能得到一些指导,这些现象表明我的适配过程中有什么地方出问题了吗? 在Jeston Nano平台适配RM500U-CN,网络连接失败
nano使用的是linux的4.9.253-tegra的英伟达魔改内核,nano最新系统也是18.04的内核版本比不上20.04版本的新,对于移远的RM500U的套件无法免驱使用,我的做法是重新编译nano的内核驱动,但是却发现nano的内核不支持USB驱动GSM和CDMA模组使用,现在先打算照着官方文档来使用PPP拨号但是这样会损失一些nano的cpu性能和传输速率
