RM520N 的 网卡模式的问题
AT+QCFG=?
+QCFG: “rrc”,(0-5)
+QCFG: “hsdpacat”,(6,8,10-24)
+QCFG: “hsupacat”,(5,6)
+QCFG: “pdp/duplicatechk”,(0,1)
+QCFG: “risignaltype”,(“respective”,“physical”)
+QCFG: “lte/bandprior”,(1-43),(1-43),(1-43),(1-43),(1-43)
+QCFG: “volte_disable”,(0,1)
+QCFG: “diversity/config”,(4,6),(1-4),(0)
+QCFG: “div_test_mode”,(0,1)
+QCFG: “usbspeed”,(“20”,“311”,“312”)
+QCFG: “data_interface”,(0,1),(0,1)
+QCFG: “pcie/mode”,(0,1)
+QCFG: “pcie_mbim”,(0,1)
+QCFG: “sms_control”,(0,1),(0,1)
+QCFG: “call_control”,(0,1),(0,1)
+QCFG: “usb/maxpower”,(0-900)
+QCFG: “efratctl”,(0,1)
+QCFG: “gatewayset”,(0,1)[,]
+QCFG: “netmaskset”,(0,1)[,]
+QCFG: “clat”,(0,1),(0,1),,(0,32,40,48,56,64,96),,(0,1),(0,1,2,4,8),(0,1),(0,1),(0,1,2),(0,1,2)
+QCFG: “usage/apmem”
+QCFG: “enable_gea1”[,(0,1)]
+QCFG: “uart”,(0,1),(0,1)
+QCFG: “mmwave”,ant_chip,ant_type,panel_value,hwid_value
请问下 这个模块不支持 关闭NAT吗 我希望把 网络下发的ipv4和ipv6 通过网口直接给到路由器
Hi @helijia21
可以帮看看你的版本里at+qmap=?有没有nat相关指令。
AT+QMAP=?
+QMAP: “WWAN”,(0,1),(1-42),<IP_family>,<IP_address>
+QMAP: “DMZ”,(0,1),(4,6),<IP_address>
+QMAP: “GRE”,(0,1),<IP_address>
+QMAP: “LAN”,<IP_address>
+QMAP: “LANIP”,<LAN_IP_start_address>,<LAN_IP_end_address>,<GW_IP_address>,
+QMAP: “MAC_bind”,(1-10),<MAC_address>,<IP_address>
+QMAP: “VLAN”,(2-255),(“enable”,“disable”),(1-3,11-13)
+QMAP: “MPDN_rule”,(0-3),(1-16),(0,2-255),(0-3),(0,1),<IPPT_info>
+QMAP: “IPPT_NAT”,(0,1)
+QMAP: “connect”,(0-3),(0,1)
+QMAP: “auto_connect”,(0-3),(0,1),(1-16)
+QMAP: “MPDN_status”
+QMAP: “AP_rule”,(0-3),(0-3)
+QMAP: “SFE”,(“enable”,“disable”)
+QMAP: “domain”,<domain_name>
+QMAP: “DHCPV6DNS”,(“enable”,“disable”)
+QMAP: “NAT_timeout”,(1-4,6),
