BC26 onenet连接 订阅资源失败
在收到+MIPLOBSERVE: 0, 79123, 1, 3303, 0, -1 之后
发送AT+MIPLOBSERVERSP=0,79123,1
我在这一步骤之后就收不到信息了,onenet客服说是我固件需要升级,可是我的bc26已经是最新的版本了啊,还有其他的可能了吗,我的BC26版本现在是BC26NCR01A09,请问在哪能找到最新的固件
onenet物联网平台上的日志记录是
auto observe /3311/0 TIME_OUT, skip following observe, discover or read
@11131 建议将onenet平台的“自动发现资源” 的按钮打开,重新测试一下看看。
现在自动订阅成果了,可是后面就一直timeout
这是onenet的物联设备日志
2021-11-28 13:56:14.079 858441936 ERROR NBBS_WRITE_ERR bootstrap write /0/0 TIME_OUT, bootstrap failed
2021-11-28 13:53:36.195 858441936 WARN NBBS_DEL_ERR bootstrap delete TIME_OUT, skip
2021-11-28 13:50:52.918 858441936 ERROR NBACC_AUTO_OBSV_ERR auto observe /3341/0 TIME_OUT, skip following observe, discover or read
2021-11-28 13:50:45.174 858441936 ERROR NBBS_WRITE_ERR bootstrap write /0/0 TIME_OUT, bootstrap failed
2021-11-28 13:50:32.905 858441936 INFO NBACC_REG register success, endpoint 863409053771357;460046697314021, lifetime 86400 s, objects [</>;rt=“oma.lwm2m”, </0/0>, </0/1>, </3341/0>]
2021-11-28 13:50:29.290 858441936 INFO NBBS_FINISH bootstrap finished on 863409053771357, return code CHANGED
2021-11-28 13:50:28.134 858441936 INFO NBBS_WRITE bootstrap wrote server address coap://183.230.40.40:5683, server id 101 to client 863409053771357, returned CHANGED
2021-11-28 13:50:24.168 858441936 INFO NBBS_DEL bootstrap delete / on client 863409053771357 return code BAD_REQUEST
2021-11-28 13:50:18.556 858441936 INFO NBBS_REQ requested bootstrap, imei 863409053771357, imsi 863409053771357
2021-11-28 13:50:14.136 858441936 INFO NBBS_REQ requested bootstrap, imei 863409053771357, imsi 863409053771357
2021-11-28 13:49:57.766 858441936 ERROR NBBS_WRITE_ERR bootstrap write /0/0 TIME_OUT, bootstrap failed
2021-11-28 13:46:53.076 858441936 WARN NBBS_DEL_ERR bootstrap delete TIME_OUT, skip
2021-11-28 13:46:07.311 858441936 WARN NBBS_DEL_ERR bootstrap delete TIME_OUT, skip
2021-11-28 13:43:18.958 858441936 INFO NBBS_REQ requested bootstrap, imei 863409053771357, imsi 863409053771357
2021-11-28 13:43:10.579 858441936 INFO NBBS_REQ requested bootstrap, imei 863409053771357, imsi 863409053771357
2021-11-28 12:38:59.843 858441936 INFO NBACC_AUTO_READ auto read /3/0 on client 863409053771357 returned NOT_FOUND
2021-11-28 12:38:58.881 858441936 INFO NBACC_AUTO_OBSV auto observe /3341/0 on client 863409053771357 returned CONTENT
2021-11-28 12:38:39.749 858441936 INFO NBACC_REG register success, endpoint 863409053771357;460046697314021, lifetime 86400 s, objects [</>;rt=“oma.lwm2m”, </0/0>, </0/1>, </3341/0>]
2021-11-28 12:38:37.492 858441936 INFO NBBS_FINISH bootstrap finished on 863409053771357, return code CHANGED
2021-11-28 12:38:36.705 858441936 INFO NBBS_WRITE bootstrap wrote server address coap://183.230.40.40:5683, server id 101 to client 863409053771357, returned CHANGED
2021-11-28 12:38:35.344 858441936 INFO NBBS_DEL bootstrap delete / on client 863409053771357 return code BAD_REQUEST
2021-11-28 12:38:34.067 858441936 INFO NBBS_REQ requested bootstrap, imei 863409053771357, imsi 863409053771357
2021-11-28 12:21:18.343 858441936 ERROR NBACC_AUTO_OBSV_ERR auto observe /3341/0 TIME_OUT, skip following observe, discover or read
2021-11-28 12:20:58.324 858441936 INFO NBACC_REG register success, endpoint 863409053771357;460046697314021, lifetime 86400 s, objects [</>;rt=“oma.lwm2m”, </0/0>, </0/1>, </3341/0>]
2021-11-28 12:20:58.310 858441936 INFO NBBS_FINISH bootstrap finished on 863409053771357, return code CHANGED
2021-11-28 12:19:55.493 858441936 INFO NBBS_WRITE bootstrap wrote server address coap://218.201.45.3:5683, server id 102 to client 863409053771357, returned CHANGED
2021-11-28 12:19:51.125 858441936 INFO NBBS_DEL bootstrap delete / on client 863409053771357 return code BAD_REQUEST
2021-11-28 12:19:43.401 858441936 INFO NBBS_REQ requested bootstrap, imei 863409053771357, imsi 863409053771357
2021-11-28 11:39:02.794 858441936 ERROR NBACC_AUTO_OBSV_ERR auto observe /3341/0 TIME_OUT, skip following observe, discover or read
2021-11-28 11:38:42.791 858441936 INFO NBACC_REG register success, endpoint 863409053771357;460046697314021, lifetime 86400 s, objects [</>;rt=“oma.lwm2m”, </0/0>, </0/1>, </3341/0>]
2021-11-28 11:38:40.966 858441936 INFO NBBS_FINISH bootstrap finished on 863409053771357, return code CHANGED
