您好,我这里有一块ec20模块,在通过核心板引出的原生串口进行交互的过程中经常存在一些问题,拨号成功时的打印如下所示,可以正常的获取到ip,并且设置好路由之后可以正常通外网。
dgri:~/test/test$ sudo ./quectel-pppd.sh
quectel-pppd options in effect:
devname /dev/ttyS6 # (default)
apn 3gnet # (default)
user user # (default)
password passwd # (default)
debug # (from command line)
nodetach # (from command line)
dump # (from command line)
noauth # (from command line)
user user # (from command line)
password ?????? # (from command line)
/dev/ttyS6 # (from command line)
9600 # (from command line)
lock # (from command line)
connect ''chat -s -v ABORT BUSY ABORT \"NO CARRIER\" ABORT \"NO DIALTONE\" ABORT ERROR ABORT \"NO ANSWER\" TIMEOUT 30 \"\" AT OK ATE0 OK ATI\\;+CSUB\\;+CSQ\\;+CPIN?\\;+COPS?\\;+CGREG?\\;\\&D2 OK AT+CGDCONT=1,\\\"IP\\\",\\\"3gnet\\\",,0,0 OK ATD*99# CONNEC
disconnect chat -s -v ABORT ERROR ABORT \"NO DIALTONE\" SAY \"\\nSending break to the modem\\n\" \"\" +++ \"\" +++ \"\" +++ SAY \"\\nGood bay\\n\" # (from command line)
nocrtscts # (from command line)
modem # (from command line)
novj # (from command line)
novjccomp # (from command line)
ipcp-accept-local # (from command line)
ipcp-accept-remote # (from command line)
noipdefault # (from command line)
ipcp-max-configure 30 # (from command line)
defaultroute # (from command line)
usepeerdns # (from command line)
noccp # (from command line)
abort on (BUSY)
abort on (NO CARRIER)
abort on (NO DIALTONE)
abort on (ERROR)
abort on (NO ANSWER)
timeout set to 30 seconds
send (AT^M)
expect (OK)
^M
-- got it
send (ATE0^M)
expect (OK)
^M
^M
-- got it
send (ATI;+CSUB;+CSQ;+CPIN?;+COPS?;+CGREG?;&D2^M)
expect (OK)
^M
^M
Quectel^M
EC20F^M
Revision: EC20CEHBR06A08M1G_GW^M
SubEdition: V06^M
+CSQ: 31,99^M
+CPIN: READY^M
+COPS: 0,0,"CHINA MOBILE",7^M
+CGREG: 0,1^M
-- got it
send (AT+CGDCONT=1,"IP","3gnet",,0,0^M)
expect (OK)
^M
^M
-- got it
send (ATD*99#^M)
expect (CONNECT)
^M
^M
CONNECT
-- got it
Script ''chat -s -v ABORT BUSY ABORT "NO CARRIER" ABORT "NO DIALTONE" ABORT ERROR ABORT "NO ANSWER" TIMEOUT 30 "" AT OK ATE0 OK ATI\;+CSUB\;+CSQ\;+CPIN?\;+COPS?\;+CGREG?\;\&D2 OK AT+CGDCONT=1,\"IP\",\"3gnet\",,0,0 OK ATD*99# CONNECT'' finished (pid 1014), status = 0x0
Serial connection established.
using channel 2
Using interface ppp0
Connect: ppp0 <--> /dev/ttyS6
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x217773eb> <pcomp> <accomp>]
rcvd [LCP ConfReq id=0x2 <asyncmap 0x0> <auth chap MD5> <magic 0xc938160f> <pcomp> <accomp>]
sent [LCP ConfAck id=0x2 <asyncmap 0x0> <auth chap MD5> <magic 0xc938160f> <pcomp> <accomp>]
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x217773eb> <pcomp> <accomp>]
rcvd [LCP DiscReq id=0x3 magic=0xc938160f]
rcvd [CHAP Challenge id=0x1 <63f6361c99b4104949bb087a8d15df9a>, name = "UMTS_CHAP_SRVR"]
sent [CHAP Response id=0x1 <b7ca44707c7f3a449f1325f2d317b3ea>, name = "user"]
rcvd [CHAP Success id=0x1 ""]
CHAP authentication succeeded
kernel does not support PPP filtering
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
sent [IPV6CP ConfReq id=0x1 <addr fe80::34e9:887d:5694:dd82>]
rcvd [IPCP ConfReq id=0x2]
sent [IPCP ConfNak id=0x2 <addr 0.0.0.0>]
rcvd [IPCP ConfNak id=0x1 <addr 10.222.141.184> <ms-dns1 111.32.26.49> <ms-dns2 111.32.0.177>]
sent [IPCP ConfReq id=0x2 <addr 10.222.141.184> <ms-dns1 111.32.26.49> <ms-dns2 111.32.0.177>]
rcvd [IPCP ConfReq id=0x3]
sent [IPCP ConfAck id=0x3]
rcvd [IPCP ConfAck id=0x2 <addr 10.222.141.184> <ms-dns1 111.32.26.49> <ms-dns2 111.32.0.177>]
Could not determine remote IP address: defaulting to 10.64.64.64
not replacing default route to enps0 [10.15.1.1]
local IP address 10.222.141.184
remote IP address 10.64.64.64
primary DNS address 111.32.26.49
secondary DNS address 111.32.0.177
Script /etc/ppp/ip-up started (pid 1018)
Script /etc/ppp/ip-up finished (pid 1018), status = 0x0
模块正常时,当发送ATI查看模块信息时可以获取到如下的信息
EC20F
但是往往模块无法正常的进行交互,通常情况下模块重新上电之后(通过电源指示灯以及网络灯观测),直接使用拨号脚本进行拨号,获取到的打印信息如下所示,由于模块回复超时,往往我在测试的过程中会重新使用拨号脚本进行测试,但是后续与模块的交互无法获得回应,即使是简单的AT也无法收到OK的回复。
abort on (BUSY)
abort on (ERROR)
send (AT^M)
expect (OK)
^M
-- got it
send (ATE0^M)
expect (OK)
^M
^M
-- got it
expect (OK)
^M
alarm
Failed
Script ''chat -s -v ABORT BUSY ABORT "NO CARRIER" ABORT "NO DIALTONE" ABORT ERROR ABORT "NO ANSWER" TIMEOUT 30 "" AT OK ATE0 OK ATI\;+CSUB\;+CSQ\;+CPIN?\;+COPS?\;+CGREG?\;\&D2 OK AT+CGDCONT=1,\"IP\",\"3gnet\",,0,0 OK ATD*99# CONNECT'' finished (pid 1081), status = 0x3
Connect script failed
模块不正常的状态下,使用串口助手与模块进行交互,会发现与正常时完全相同的串口助手设置,仅仅按下键盘的第一个键就会收到ok的回复,而且无论按下哪个键都会收到这样的回复,按下第二个键时收到的就是乱码了,再之后无论选择脚本进行交互还是使用串口助手都无法收到模块的回复,详细的打印信息如下。
dgri:~/test/test$ sudo ./picocom /dev/ttyS6
picocom v3.2a
port is : /dev/ttyS6
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
stopbits are : 1
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
hangup is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv -E
imap is :
omap is :
emap is : crcrlf,delbs,
logfile is : none
initstring : none
exit_after is : not set
exit is : no
Type [C-a] [C-h] to see available commands
Terminal ready
怘þ怘
在上面所有的测试过程中使用的串口通讯的波特率等设置是完全相同的。目前我遇到的问题是,在非常多次的测试过程中,往往模块是不正常的状态,仅有很少次是正常的,可以拨号成功的,请问我应该尝试从哪些方面解决这个问题呢
