请问RM500U是否可以通过PPP进行连接通信,我尝试用stm32h7 lwip进行PPP连接,我完成LCD连接后,在ipcp遇到模组错误
我已经调试了大约2周-3周时间了,我想确认一下是不是rm500u,在单片机情况下进行PPP通信是有问题的,我的模组固件是RM500UCNAAR02A04M2G_01.001.01.001
现在情况是我通过取消掉PPP LCD Magicnumber建立LCD连接,没有使用pap用户认证,直接在IPCP的阶段获取IP地址情况下返回+CME ERROR: 4,所以我想确认RM500U是否可以建立PPPos通信,我在材料上看是支持PPP通信,以下是我的AT指令以及PPP记录
RDY
AT
AT+CMEE=2
AT+QCFG=“usbnet”,5
AT+QCFG=“nat”,0
A
T+CFUN=1
AT+CIMI
460099035700874
AT+CGDCONT?
+CGDCONT: 1,"IPV4V
6",“3gnet”,“0.0.0.0”,0,0,0,0,0,0,0,0,0,0
+CGDCONT: 2,“IP”,“zjbg”,“0.0.0.0”,0,0,0,0,0,0,0,0,0,0
+CGDCONT: 11,"I
PV4V6",“ims”,“0.0.0.0”,0,0,0,2,0,0,0,0,0,0
AT+QNETDEVCTL=1,3,1
AT+QNETDEVSTATUS=1
+CME ERROR:
3
AT+QNETDEVSTATUS=1
+QNETDEVSTATUS: 172.31.4.232,255.255.255.0,
172.31.4.1,10.99.200.121,210.21.4.130,
AT+CGDATA=“PPP”,1
ppp phase changed[0]: phase=0
ppp_connect[0]: holdof
f=0
ppp phase changed[0]: phase=3
pppos_connect: unit 0: connecting
ppp_start[0]
ppp phase changed[0]: phase=6
pppos_send_config
[0]: out_accm=FF FF FF FF
ppp_send_config[0]
pppos_recv_config[0]: in_accm=FF FF FF FF
ppp_recv_
config[0]
ppp: auth protocols: PAP=1 CHAP=0 CHAP_MD5=0
sent [LCP ConfReq id=0x1 <asyncmap 0x0> ]
pppos_write[0]: len=18
ppp_start[0]: finished
~}#}!}!} }.}"}&}pppos_input[0]: got 37 bytes
rc
vd [LCP ConfReq id=0x1 <asyncmap 0x0> ]
sent [LCP ConfAck id=0x1 <asyncmap 0x0>
"N穨pppos_input[0]: got 36 bytes
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> ]
netif
_set_mtu[0]: mtu=1500
pppos_send_config[0]: out_accm=0 0 0 0
ppp_send_config[0]
pppos_recv_config[0]: in_accm=0 0 0 0
ppp_recv_c
onfig[0]
ppp phase changed[0]: phase=7
ppp phase changed[0]: phase=9
sent [IPCP ConfReq id=0x1 <
addr 0.0.0.0>]
pppos_write[0]: len=14
+CME ERROR: 4
pppos_input[0]: got 25 bytes
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0>]
+CME ERROR: 4
pppos_input[0]: Dropping bad fcs 0x3518 pr
oto=0x8021
pppos_input_drop: pbuf len=22, addr 2404e170
+CME ERROR: 4
pppos_inpu
t[0]: Dropping bad fcs 0x3518 proto=0x8021
+CME ERROR: 4
pppos_input[0]: Dropping bad fcs 0x3518 proto=0x8021
+CME ERROR: 4
+CME ERROR: 4
+CME ERROR: 4
pppos_i
+CME ERROR: 4
oto=0x8021
+CME ERROR: 4
pppos_inpu
+CME ERROR: 4
IPCP: timeout sending Config-Req
uests
ppp phase changed[0]: phase=11
pppos_send_config[0]: out_accm=FF FF FF FF
ppp_send_config[0]
0 0 0
ppp_recv_config[0]
sent [LCP TermReq id=0x2 “No network protocols running”]
pppos_write[0]: len=36
~}#}%}"} No network protocols running}7}8~pppos_input[0]: got 46 bytes
ddr 2404e170
rcvd [LCP TermReq id=0x2 “No network protocols running”]
sent [LCP TermAck id=0x2]
pppos_write[0]: len=8
~}#}&}"} }$攠-~pppos_input[0]: got 18 bytes
rcvd [LCP TermAck id=0x2]
ppp phase changed[0]: phase=12
Connection terminated.
ppp_link_terminated[0]
ppp_link_e
nd[0]
status_cb: Connection lost
ppp_connect[0]: holdoff=30
ppp phase changed[0]: phase=2
ppp_link_terminated[0]: finished.
麻烦了
这是用串口还是用USB。
在进行ppp拨号后不应该去自己发送AT指令了。
在IPCP的时候串口应该已经要进入数传模式。
还有,可以不要去发AT+QNETDEVCTL拨号了。
谢谢回复,我这个例子是串口的,我晚上试试看,就是默认只要切到 AT+CGDATA=“PPP”,1 数传模式就可以了是么
好像还是不可以,AT+QNETDEVCTL去掉后情况差不多
RDY
AT
AT+CMEE=2
AT+QCFG=“usbnet”,5
AT+QCFG=“nat”,0
A
T+CFUN=1
AT+CIMI
460099035700874
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“3gnet”,“0.0.0.0”,0,0,0,0,
,0,0,0,0,0,0
+CGDCONT: 11,“IPV4V6”,“ims”,“0.0.0.0”,0,0,0,2,
,0,0,0,0,0,0
AT+CGDATA=“PPP”,1
ppp_connect[0]:
holdoff=0
ppp_start[0]
pppos_send_
ppp_send_config[0]
ppp
_recv_config[0]
}"p4~pppos_input[0]: got 37 bytes
rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> ]
sent
~}#}“}!} }.}”}&} } } } }'}"}(}"N穨pppos_input[0]: got 37 bytes
cmap 0x0> ]
netif_set_mtu[0]: mtu=1500
ppp_send_config[0]
pppos_recv_conf
ppp_recv_config[0]
+CME ERROR: 4
+CME ERROR: 4
pppos_inpu
pppos_input_drop: pbuf len=22, addr 2404e0f4
在ATD*99#以后就不要再去发AT命令了
屏幕截图 2024-10-31 060958
用atd99**1#好像也不能进入数传模式,我感觉rm500u这块资料的确少
哦对了,我这里是私网5G网络,每张sim卡是固定ip地址的
RM500U ATD*99# 这条命令不可以用的,+CME ERROR:error, 我用的是AT+CGDATA=“PPP”,1,我感觉我是不是一直没有打开数传模式
我建议你在Windows 或者Linux 上试下这个ppp。
专网卡一般只会给你准备一个ip地址,如果已经做了其他拨号,ppp 应该是没法拨号成功的。
ATD*99# 是公网卡做ppp 拨号的时候要使用
请问一下,windows上怎么测试ppp,我试了一下windows usbnet:RNDIS,倒是默认可以连接的上私网ip,而且分配地址也对
我主要是用rm500u,内置AT指令发送TCP数据包,感觉性能太差了,好像收到限制比较严重,一次数据包蔡1460,间隔限制,上行最多40k,所以才想用PPP外部连接通过外部协议栈跳过这些限制,工业上用linux不稳定的情况太多了,希望用单片机直接带起来,可惜我调了好2,3周了呵呵
单片机怎么用ppp,我们没有这个经验。
Windows 就是使用系统自带的拨号。可以参考文档
我按照文件《Quectel_LTE_Standard(A)系列_PPP_应用指导_V1.5》内容里面的windows配置试过了,应该擦欧总没有错
1我使用移动公网SIM卡5G
2建立调制解调器端口我用usb at com22
ANP设置AT+CGDCONT=1,“IP”,“CMNET”
1
3 调制解调器我设置115200
4 建立拨号选择新建调制解调器,然后拨号用*99#
2
3
5 最后连接还是失败 678
4
但是在usb串口里进行拨号是成功的
5
这个是不是证明RM500U,是不是默认不支持PPP通信,或者我用的固件版本不支持PPP,方便确认一下么
如果RM500U不行的话方便推荐一下固件或者其他模组么
你可以换个公网卡试试。怀疑和专网卡有关。
5G一般不会再使用ppp了,但是应该是支持的,在spec或者releasenote 里可以看到。
如果PPP不行的话,考虑单片机RNDIS驱动了,本来以为PPP是最简单的
不过传统工业上使用,特别是通信私网改造,一般不会用linux,因为如果linux相对于硬实时系统或者单片机来说,还是单片机稳定很多,而且linux工作环境要求也很高,希望这个可以调通比较有价值,还有除了PPP以外,你们有考虑过单片机连接5G么
我目前用的就是公网卡,不过板子是自己做的,按照你们指导文件,我猜想ppp应该和硬件无关吧
RM500U-CN PPPOS 是支持的,usb连接的话要用默认驱动创建的调制解调器,公网sim是可以的,其他端口不行
RM500U_PPP
移远在搞STM32,基于移远自己的TCP/MQTT/TCP使用AT指令. 但是应该是基于FreeRTOS的,并且只有AT指令,不包括usbnet还有ppp这类需求。
(https://github.com/Quectel-user-friendly-develop/STM32)
如果使用单片机接移远的5G模组,对模组性能也浪费。在网上搜,应该可以搜到一些但是都是基于4G模组。
这个项目看介绍好像只是封装AT指令的,如果可以使用外部协议栈提高性能的话蛮好,如果只是单独代替AT指令做个SDK封装好像意思不大
