再调试RM520N的PCIE模式时碰到了问题
主机是使用的MT7621, 目前再主机端能枚举到PCIE设备,但是没有生成mhinet设备
模块版本号是: RM520NEUDAR03A04M4G_01.200.01.200
模块已经通过AT命令切换成pcie模式和EP模式
mhi相关日志:
[   23.365311] mhi_init Quectel_Linux_PCIE_MHI_Driver_V1.3.4
[   23.377012] mhi_pci_probe pci_dev->name = 0000:02:00.0, domain=0, bus=2, slot=0, vendor=17CB, device=0308
[   23.396615] mhi_q 0000:02:00.0: BAR 0: assigned [mem 0x60100000-0x60100fff 64bit]
[   23.411581] PCI: Enabling device 0000:00:01.0 (0004 -> 0006)
[   23.422864] PCI: Enabling device 0000:02:00.0 (0000 -> 0002)
[   23.434194] [I][mhi0][mhi_init_pci_dev] msi_required = 5, msi_allocated = 1, msi_irq = 25
[   23.434212] [I][mhi0][mhi_power_up] dev_state:RESET
[   23.434218] [I][mhi0][mhi_async_power_up] Requested to power on
[   23.434645] [I][mhi0][mhi_alloc_coherent] size = 114688, dma_handle = efc0000
[   23.434653] [I][mhi0][mhi_init_dev_ctxt] mhi_ctxt->ctrl_seg = aefc0000
[   23.435158] [I][mhi0][mhi_async_power_up] dev_state:RESET ee:AMSS
[   23.435257] [I][mhi0][mhi_async_power_up] Power on setup success
[   23.435298] [I][mhi0][mhi_pci_show_link] LnkCap:     Speed 16GT/s, Width x2
[   23.435305] [I][mhi0][mhi_pci_show_link] LnkSta:     Speed 2.5GT/s, Width x1
[   23.435309] [I][mhi0][mhi_pci_probe] Return successful
[   23.435621] [I][mhi0][mhi_pm_st_worker] Transition to state:READY
[   23.435640] [I][mhi0][mhi_pm_st_worker] INVALID_EE -> AMSS
[   23.435648] [I][mhi0][mhi_ready_state_transition] Waiting to enter READY state
[   23.441990] usbcore: registered new interface driver cdc_wdm
[   23.457222] ip_tables: (C) 2000-2006 Netfilter Core Team
[   26.226038] register mt_drv
[   26.231731] bus=0x1, slot = 0x0, irq=0x0
[   26.239543] PCI: Enabling device 0000:00:00.0 (0004 -> 0006)
[   26.266386]
[   26.266386] == pAd = c0c01000, size = 4165120, Status=0 ==
[   26.280279] pAd->PciHif.CSRBaseAddress =0xc0b00000, csr_addr=0xc0b00000!
[   26.293620] RTMPInitPCIeDevice():device_id=0x7615
[   26.302987] mt_pci_chip_cfg(): HWVer=0x8a10, FWVer=0x8a10, pAd->ChipID=0x7615
[   26.317212] mt_pci_chip_cfg(): HIF_SYS_REV=0x76150001
[   26.327265] AP Driver version-5.0.4.0
[   26.334555] RtmpChipOpsHook(223): Not support for HIF_MT yet! MACVersion=0x0
[   26.348578] mt7615_init()-->
[   26.354310] Use 1st ePAeLNA default bin.
[   26.362114] Use 0st /etc_ro/wlan/MT7615E_EEPROM1.bin default bin.
[   26.374254] <--mt7615_init()
[   26.383922] <-- RTMPAllocTxRxRingMemory, Status=0
[   26.393617] RtmpOSFileOpen(): Error 2 opening /etc/wireless/l1profile.dat
[   26.470239] [I][mhi0][mhi_ready_state_transition] Device in READY State
[   26.470260] [I][mhi0][mhi_tryset_pm_state] Transition to pm state from:POR to:POR
[   26.470268] [I][mhi0][mhi_init_mmio] Initializing MMIO
[   26.470277] [I][mhi0][mhi_init_mmio] CHDBOFF:0x300
[   26.470290] [I][mhi0][mhi_init_mmio] ERDBOFF:0x700
[   26.470297] [I][mhi0][mhi_init_mmio] Programming all MMIO values.
root@OutdoorRouter:~# lspci -vv
00:00.0 PCI bridge: Device 0e8d:0801 (rev 01) (prog-if 00 [Normal decode])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 255
        Region 1: Memory at 60200000 (32-bit, non-prefetchable) [size=64K]
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: None
        Memory behind bridge: 60000000-600fffff [size=1M]
        Prefetchable memory behind bridge: None
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0
                        ExtTag- RBE+
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <64us
                        ClockPM- Surprise- LLActRep+ BwNot- ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
                RootCap: CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd-
                         AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                         AtomicOpsCtl: ReqEn- EgressBlck-
                LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
                RootCmd: CERptEn- NFERptEn- FERptEn-
                RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
                         FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
                ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
        Capabilities: [140 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending- InProgress-
lspci: Unable to load libkmod resources: error -12
00:01.0 PCI bridge: Device 0e8d:0801 (rev 01) (prog-if 00 [Normal decode])
        Latency: 0
        Region 1: Memory at 60210000 (32-bit, non-prefetchable) [size=64K]
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        Memory behind bridge: 60100000-601fffff [size=1M]
                        ExtTag- RBE+
                Status: InProgress-
01:00.0 Unclassified device [0002]: MEDIATEK Corp. Device 7615 (prog-if 80)
        Subsystem: Device 7615:14c3
        Latency: 0, Cache Line Size: 80 bytes
        Interrupt: pin A routed to IRQ 24
        Region 0: Memory at 60000000 (64-bit, non-prefetchable) [size=1M]
        Capabilities: [78] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [80] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <2us, L1 <2us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 128 bytes
                LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <2us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
        Capabilities: [100 v1] Virtual Channel
                Status: InProgress-
        Kernel driver in use: mt_drv
02:00.0 Unassigned class [ff00]: Qualcomm Device 0308
        Subsystem: Qualcomm Device 5201
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin ? routed to IRQ 25
        Region 0: Memory at 60100000 (64-bit, non-prefetchable) [size=4K]
        Region 2: Memory at 60101000 (64-bit, non-prefetchable) [size=4K]
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
                Masking: 00000000  Pending: 00000000
        Capabilities: [70] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 16GT/s, Width x2, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
        Capabilities: [100 v2] Advanced Error Reporting
        Capabilities: [148 v1] #19
        Capabilities: [168 v1] #26
        Capabilities: [18c v1] #27
        Capabilities: [19c v1] Transaction Processing Hints
                No steering table available
        Capabilities: [228 v1] Latency Tolerance Reporting
                Max snoop latency: 0ns
                Max no snoop latency: 0ns
        Capabilities: [230 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=70us PortTPowerOnTime=0us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=0us LTR1.2_Threshold=0ns
                L1SubCtl2: T_PwrOn=10us
        Capabilities: [240 v1] #25
        Kernel driver in use: mhi_q
想咨询下可能是什么问题
modem的串口有如下日志
Starting udev Kernel Device Manager...
[FAILED] Failed to start pcie Service.
See 'systemctl status pcie.service' for details.
cat /proc/interrupts
看看。
连 /dev/mhi_BHI 都没有吗
/dev/mhi_BHI 生成了, 但只有这个。
mt7621似乎不支持msi,使用的传统intx,alloc irq是添加了PCI_IRQ_LEGACY, 这样是否有问题
ret = pci_alloc_irq_vectors(pci_dev, 1, mhi_cntrl->msi_required, PCI_IRQ_MSI | PCI_IRQ_LEGACY);
irq如下
root@OutdoorRouter:~# cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
  8:    1983554    1983542    1983542    1983526  MIPS GIC Local   1  timer
  9:     331292          0          0          0  MIPS GIC  63  IPI call
 10:          0     423446          0          0  MIPS GIC  64  IPI call
 11:          0          0     863771          0  MIPS GIC  65  IPI call
 12:          0          0          0     332856  MIPS GIC  66  IPI call
 13:     190219          0          0          0  MIPS GIC  67  IPI resched
 14:          0     273407          0          0  MIPS GIC  68  IPI resched
 15:          0          0     192693          0  MIPS GIC  69  IPI resched
 16:          0          0          0     177931  MIPS GIC  70  IPI resched
 18:         12          0          0          0  MIPS GIC  33  ttyS0
 20:          0          0          0          0  MIPS GIC  18  1e007000.hsdma
 21:       2129          0          0          0  MIPS GIC  29  xhci-hcd:usb1
 22:    1114196          0          0          0  MIPS GIC  10  1e100000.ethernet
 23:          1          0          0          0  MIPS GIC  30  gsw
 24:    1041376          0          0          0  MIPS GIC  11  ra0
 25:          0          0          0          0  MIPS GIC  31  mhi
必须要使用 MSI中断的。既然确定不支持MSI中断,那么这个就无法搭配使用。考虑下USB 3.0 吧
我的也是只有mhi_BHI设备,怎么解决呢?
只有/dev/mhi_DUN 通常可能是开机时序不满足模组的要求。
您好,请问我这边在加载pcie_mhi,ko驱动后,通过fuser -v /dev/mhi_DUN 命令查看设备节点识别进程占用的,但是这个时候 我手动 rmmod pcie_mhi驱动还是可以成功的。按驱动的正常流程来说,设备节点被占用的时候,rmmod应该会提示“ERROR: Module xxxx is in use”,但是为什么pcie_mhi驱动可以移除成功呢?请问这块引用计数是如何处理的
