EC800上电串口没有接收rad
请问上电的时序是?,没有连接硬件,只通过status引脚判断是否可靠。目前上电接收报错见日志
[INFO: CPU ] CHIP_ID: 0x1606, REV_ID: 0xA0
[INFO: CPU ] PLATFORM: CRANEL (SILICON)
[INFO: Main ]
[INFO: Main ] Starting AROM-CRANE (Version: 2021.10.16)
[INFO: ClkDrv ] QSPI clock configured at 13 MHz
[INFO: QspiFlash ] QSPI clock configured at level 1
[INFO: QspiFlash ] Detecting QSPI flash devices…
[INFO: QspiFlash ] Found a known spi flash device “GD25LQ64C”
[INFO: QspiFlash ] SPI nor flash: Manufacturer ID: 0xC8, Device ID: 0x6017
[INFO: UbiSimple ] Detected peb size is 4096, the first good peb number is 0
[INFO: Crypto ] Initializing crypto library…
[INFO: Main ] Running in normal booting mode.
[INFO: Main ] Loading…
[INFO: Bl1Main ] Welcome to boot rom.
[INFO: Bl1Main ] ### Non-trusted boot mode. ###
[INFO: Bl1Main ] Found preboot volume, size is 19384 bytes
[INFO: Bl1Main ] BL1: Trying to load and verify BL2 image from volume preboot…
[INFO: BlCommon ] Loading image from #0xd1f0d818 to #0x80 with size 31528 successfully.
[INFO: Bl1Main ] BL1: OKay.
[INFO: Freq ] Freq change done: CR5 416MHz → 624MHz, AXI 156MHz → 208MHz
[PRI : Preboot ] Executing preboot application…
[PRI : Preboot ] Preboot version: 2023.03.03
[PRI : Preboot ] PMIC REG:0x01,0x10,0xe5,0xe6,0xe2,0xeb
[PRI : Preboot ] PMIC VAL:0x02,0x02,0x04,0x00,0xf2,0x05
[PRI : Preboot ] cold power on
[PRI : Preboot ] long press, do poweron!!
[PRI : PMIC ] Found PMIC with Id: 0x18
[PRI : PMIC ] [BP_0xe5] = 0x0
[PRI : PMIC ] [BP_0xe6] = 0x0
[PRI : Psram ] [PSRAM] psram init Crane common.
[PRI : Psram ] WB_250MHZ_8M
[PRI : EFuse ] No embedded flash
[PRI : Psram ] [PSRAM] psram init set WBD drive_strength = WBD_DRIVE_115ohm .
[PRI : Psram ] CraneW & CraneL_A0 & CraneL_S: phy config
[INFO: Bl1Main ] Found bootloader volume, size is 36312 bytes
[INFO: Bl1Main ] BL1: Trying to load and verify BL2 image from volume bootloader…
[INFO: BlCommon ] Loading image from #0x7e000128 to #0x80 with size 13196 successfully.
[WARN: Boot2 ] usb is not connected
[ERR : SecureBoot] Flash init fail!
[INFO: BlCommon ] Loading image from #0x7e0023e0 to #0x7e100000 with size 35858 successfully.
[BOOT33]VB_VERSION_DATE :[20221209]
Qspi clk=104, QSPI_CLK_RES_CTRL = 0x1db, mfr_id=0xc8,dev_id:0x6017
[Quec][Flash]:Abnormal Erasedblock not found(i=3004)
[LOGO] VERSION_DATE :[20221209]
** PC : 0x80022000
Version: SDK_1.010.087 Jun 27 2023 13:51:31
Ac 4, Board 2, DKB 1
0
Cinit 2
Flash type: nvm 0, factory 0, fota 0
0 silentreset, don’t need to dump
Phase1Inits
diag Phase1 Init
SVT 131
profile num = 2
CRNL_SVC_FP[0] = 0x18
CRNL_SVC_FP[1] = 0x19
CRNL_SVC_FP[2] = 0x1b
CRNL_SVC_FP[3] = 0x21
PSRAM fuse: 7
Bootup not silent
0 [MPU][RGN][ BASE][ END][ SIZE][ PERMISSION][CACHE][SHARE][N_EXE]
0 [MPU][ 0][0x00000000][0xffffffff][0xffffffff][ NO_ACCESS][ 0][ 1][ 1]
0 [MPU][ 1][0x00000000][0x0000ffff][0x0000ffff][ READ_ONLY][ 0][ 0][ 0]
0 [MPU][ 2][0xb0020000][0xb002ffff][0x0000ffff][ FULL_ACCESS][ 0][ 0][ 1]
0 [MPU][ 3][0x80000000][0x807fffff][0x007fffff][ FULL_ACCESS][ 0][ 0][ 0]
0 [MPU][ 4][0x7e000000][0x7e7fffff][0x007fffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 5][0x7e700000][0x7e7fffff][0x000fffff][ FULL_ACCESS][ 0][ 1][ 0]
0 [MPU][ 6][0xc0000000][0xffffffff][0x3fffffff][ FULL_ACCESS][ 0][ 0][ 1]
0 [MPU][ 7][0xd1000000][0xd100ffff][0x0000ffff][ FULL_ACCESS][ 0][ 1][ 1]
0 [MPU][ 8][0x80000000][0x803fffff][0x003fffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 9][0x80400000][0x805fffff][0x001fffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 10][0x80600000][0x8067ffff][0x0007ffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 11][0x80680000][0x806bffff][0x0003ffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 12][0x00000000][0x00000001][0x00000001][ NO_ACCESS][ 1][ 0][ 0]
0 [MPU][ 13][0x00000000][0x00000001][0x00000001][ NO_ACCESS][ 1][ 0][ 0]
0 [MPU][ 14][0x00000000][0x00000001][0x00000001][ NO_ACCESS][ 1][ 0][ 0]
0 [MPU][ 15][0x80000000][0x80000001][0x00000001][ NO_ACCESS][ 1][ 0][ 1]
169 XML VERSION:QCFG=7,IMS=7
16b XML USER INFO:QCFG=0,IMS=0
1cd XML CRC:QCFG=0x8461E12C,FILE=0x8461E12C,IMS=0x8461E12C
285 XML DON’T NEED OPERATE
11a0 usbinfo trace to uart debugfail
1641 quec usb nema cfg nv init: value 0 read failed
24 [Egan]usb_device_init,usb_mode=69
24 Usb mode 0, descriptor 69
2f power_up_reason: 0x2, power_down_reason: 0x4
1ef9 read g_quec_nat_flag=0 fail
1efd mifi mode
31 lwip: lwip_init_all done!
32 ######## quec_system_init ok ########
32 EC800MCNGAR06A06M08 V02
33 Application Start…
33 ATCmdSvrRdy
2959 usb get ifc value fail rts_control=0,cts_control=0
29e7 read remoteip=0,ret=5
29f1 remoteip read fail
2acc cts value=0 not need init
2b86 debounce timer read fail,use default value
2cb0 usim wakeup flag read fail,use default value=0
62 InitIPCControl: data:0x0
7c quec_modem_channel_init: done
7c modem_msgq_init: done
7c modem_if_init: done
7d modem_router_create: done
7d modem_init_internal: done
7e AT command server ready!
7f Booting done
5dde dsss sim2 read_cfg=1,dftcid=1
97 quec_transmission_rate_config!!!
97 audio_init!!!
97 quec_audio_gain_table_config!!!
6517 quec_i2c_init quec_i2c_init=0x60
9d mode = 0 mode = 0
9f quec_rt5616_read_reg!!!
6604 Error: bus error detected,0x68,0x406!
66b4 quec_i2c_init quec_i2c_init=0x60
66ee Error:Write cmdlen 0
6748 Error: bus error detected,0x68,0x406!
6806 quec_i2c_init quec_i2c_init=0x60
6840 Error:Write cmdlen 0
6952 Error: bus error detected,0x68,0x406!
69bf quec_i2c_init quec_i2c_init=0x60
69fa Error:Write cmdlen 0
6a54 Error: bus error detected,0x60,0x446!
6b40 quec_i2c_init quec_i2c_init=0x60
a7 Error:Write start+slaveaddress
6bf0 Error: bus error detected,0x68,0x406!
6cad quec_i2c_init quec_i2c_init=0x60
6ce8 Error:Write cmdlen 0
6d43 Error: bus error detected,0x60,0x446!
6e00 quec_i2c_init quec_i2c_init=0x60
ab Error:Write start+slaveaddress
6eb4 Error: bus error detected,0x60,0x446!
6f72 quec_i2c_init quec_i2c_init=0x60
ae Error:Write start+slaveaddress
7026 Error: bus error detected,0x68,0x406!
70e5 quec_i2c_init quec_i2c_init=0x60
711f Error:Write cmdlen 0
7178 Error: bus error detected,0x60,0x446!
7238 quec_i2c_init quec_i2c_init=0x60
b2 Error:Write start+slaveaddress
72ea Error: bus error detected,0x68,0x406!
73a8 quec_i2c_init quec_i2c_init=0x60
73e3 Error:Write cmdlen 0
b9 SW restart reason: Charging in powering off
476 PowerControl Entrance
4bc net ready…
4bc powerctl start
4bf flash ready…
6ba powerctl ready…
6ba shut down
6ba +PMIC_SW_POWER      [INFO: CPU ] CHIP_ID: 0x1606, REV_ID: 0xA0
[INFO: Main ]
[Quec][Flash]:Abnormal Erasedblock not found(i=3020)
** PC : 0x80022000
0
Cinit 2
Phase1Inits
diag Phase1 Init
SVT 130
profile num = 2
PSRAM fuse: 7
Bootup not silent
1ce XML CRC:QCFG=0x8461E12C,FILE=0x8461E12C,IMS=0x8461E12C
11b7 usbinfo trace to uart debugfail
1657 quec usb nema cfg nv init: value 0 read failed
1f00 read g_quec_nat_flag=0 fail
1f04 mifi mode
33 ATCmdSvrRdy
295d usb get ifc value fail rts_control=0,cts_control=0
29eb read remoteip=0,ret=5
29f5 remoteip read fail
2ad2 cts value=0 not need init
2b8b debounce timer read fail,use default value
2cb3 usim wakeup flag read fail,use default value=0
7e quec_modem_channel_init: done
7e modem_msgq_init: done
7f modem_if_init: done
7f modem_router_create: done
80 modem_init_internal: done
80 AT command server ready!
82 Booting done
5f81 dsss sim2 read_cfg=1,dftcid=1
99 quec_transmission_rate_config!!!
99 audio_init!!!
9a quec_audio_gain_table_config!!!
671c quec_i2c_init quec_i2c_init=0x60
a0 mode = 0 mode = 0
a1 quec_rt5616_read_reg!!!
67d4 Error: bus error detected,0x68,0x406!
6896 quec_i2c_init quec_i2c_init=0x60
6914 Error:Write cmdlen 0
692c Error: bus error detected,0x60,0x446!
69eb quec_i2c_init quec_i2c_init=0x60
a5 Error:Write start+slaveaddress
6ad1 Error: bus error detected,0x68,0x406!
6b5c quec_i2c_init quec_i2c_init=0x60
6b97 Error:Write cmdlen 0
6c45 Error: bus error detected,0x68,0x406!
6cd7 quec_i2c_init quec_i2c_init=0x60
6d11 Error:Write cmdlen 0
6d6b Error: bus error detected,0x68,0x406!
6e29 quec_i2c_init quec_i2c_init=0x60
6e64 Error:Write cmdlen 0
6ebe Error: bus error detected,0x60,0x446!
6f7b quec_i2c_init quec_i2c_init=0x60
7030 Error: bus error detected,0x68,0x406!
70ee quec_i2c_init quec_i2c_init=0x60
7128 Error:Write cmdlen 0
7182 Error: bus error detected,0x68,0x406!
7241 quec_i2c_init quec_i2c_init=0x60
727b Error:Write cmdlen 0
72d5 Error: bus error detected,0x60,0x446!
7393 quec_i2c_init quec_i2c_init=0x60
b4 Error:Write start+slaveaddress
7447 Error: bus error detected,0x68,0x406!
7504 quec_i2c_init quec_i2c_init=0x60
7540 Error:Write cmdlen 0
bc SW restart reason: Charging in powering off
12e PowerControl Entrance
16a net ready…
16a powerctl start
16c flash ready…
206 PowerControl Entrance
206 net ready…
206 enter towice!!!
364 powerctl ready…
364 shut down
396 +PMIC_SW_POWERDa 
你好
可以先看下模块外围硬件是否有异常 ,
