EM05 Linux qmi模式获取到ip后无法访问网络
联通的卡和移动的卡都测试了,测试电脑(Ubuntu)和路由器(openwrt)和Windows都是这个情况,表现为能访问短信/电话,能通过QMI拿到ip地址,但是就是无法连接网络,ping网关、tcp尝试连接业务服务器均无相应。sim卡在其他设备测试是可以用的。
日志:
ModemManager[81031]: <info>  ModemManager (version 1.20.6) starting in system bus...
ModemManager[81031]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.1/0000:02:00.0': not supported by any plugin
ModemManager[81031]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:03:00.0': not supported by any plugin
ModemManager[81031]: <warn>  [ttyUSB0/probe] failed to parse QCDM version info command result: -7
ModemManager[81031]: <info>  [device /sys/devices/pci0000:00/0000:00:08.1/0000:35:00.4/usb3/3-2] creating modem with plugin 'quectel' and '6' ports
ModemManager[81031]: <info>  [base-manager] modem for device '/sys/devices/pci0000:00/0000:00:08.1/0000:35:00.4/usb3/3-2' successfully created
ModemManager[81031]: <warn>  [modem0] couldn't query SIM slots: QMI SIM slot switch operation not supported
ModemManager[81031]: <warn>  [modem0/sim0] couldn't load list of emergency numbers: uninitialized emergency numbers list
ModemManager[81031]: <warn>  [modem0] couldn't load list of own numbers: Couldn't get MSISDN: QMI protocol error (16): 'NotProvisioned'
ModemManager[81031]: <warn>  [modem0] couldn't load ESN: Device doesn't report a valid ESN
ModemManager[81031]: <warn>  [modem0] couldn't load supported assistance data types: LOC service: general failure
ModemManager[81031]: <info>  [modem0] state changed (unknown -> disabled)
ModemManager[81031]: <info>  [modem0] state changed (disabled -> enabling)
ModemManager[81031]: <info>  [modem0] simple connect started...
ModemManager[81031]: <info>  [modem0] simple connect state (4/10): wait to get fully enabled
ModemManager[81031]: <info>  [modem0] power state updated: on
ModemManager[81031]: <info>  [modem0] state changed (enabling -> enabled)
ModemManager[81031]: <info>  [modem0] simple connect state (5/10): wait after enabled
ModemManager[81031]: <info>  [modem0] 3GPP registration state changed (unknown -> registering)
ModemManager[81031]: <info>  [modem0] simple connect state (6/10): register
ModemManager[81031]: <info>  [modem0] 3GPP registration state changed (registering -> home)
ModemManager[81031]: <info>  [modem0] state changed (enabled -> registered)
ModemManager[81031]: <info>  [modem0] simple connect state (7/10): wait to get packet service state attached
ModemManager[81031]: <info>  [modem0] simple connect state (8/10): bearer
ModemManager[81031]: <info>  [modem0] simple connect state (9/10): connect
ModemManager[81031]: <info>  [modem0] state changed (registered -> connecting)
ModemManager[81031]: <info>  [modem0/bearer1] QMI IPv4 Settings:
ModemManager[81031]: <info>  [modem0/bearer1]     address: 10.10.13.223/26
ModemManager[81031]: <info>  [modem0/bearer1]     gateway: 10.10.13.224
ModemManager[81031]: <info>  [modem0/bearer1]     DNS #1: 218.2.2.2
ModemManager[81031]: <info>  [modem0/bearer1]     DNS #2: 218.4.4.4
ModemManager[81031]: <info>  [modem0/bearer1]        MTU: 1500
ModemManager[81031]: <info>  [modem0/bearer1] couldn't start network: QMI protocol error (14): 'CallFailed'
ModemManager[81031]: <info>  [modem0/bearer1] verbose call end reason (6,38): [3gpp] network-failure
ModemManager[81031]: <info>  [modem0/bearer1] reloading stats is supported by the device
ModemManager[81031]: <info>  [modem0] state changed (connecting -> connected)
ModemManager[81031]: <info>  [modem0] simple connect state (10/10): all done
ModemManager[81031]: <info>  [modem0/bearer1] verbose call end reason (3,1028): [cm] emm-detached
ModemManager[81031]: <info>  [modem0] state changed (connected -> registered)
ModemManager[81031]: <info>  [modem0/bearer1] connection #1 finished: duration 0s, tx: 0 bytes, rx: 0 bytes
ModemManager[81031]: <info>  [modem0] 3GPP registration state changed (home -> registering)
ModemManager[81031]: <warn>  [modem0/bearer1] reloading stats failed: Couldn't get packet statistics: QMI protocol error (15): 'OutOfCall'
ModemManager[81031]: <info>  [modem0] state changed (connecting -> registered)
ModemManager[81031]: <info>  [modem0] state changed (registered -> connected)
ModemManager[81031]: <info>  [modem0/bearer1] connection #2 finished: duration 0s, tx: 0 bytes, rx: 0 bytes
ModemManager[81031]: <info>  [modem0/bearer1] connection #3 finished: duration 0s, tx: 0 bytes, rx: 0 bytes
ModemManager[81031]: <info>  [modem0/bearer1] reloading stats is not supported by the device
ModemManager[81031]: <warn>  [modem0] couldn't load network timezone from the current network
# ifconfig wwan0
wwan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.10.13.223  netmask 255.255.255.192  destination 10.10.13.223
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 230  bytes 30312 (30.3 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
# ip r
default via 10.10.13.224 dev wwan0 proto static metric 700
# ping 10.10.13.224
# curl 47.93.12.178
使用 AT+QCFG=“usbnet” 指令切换模式后,ECM模式可以使用,但是RmNet和mbim都不行
你好
可以尝试使用如下工具拨号验证
链接: 百度网盘 请输入提取码 提取码: pc7a 复制这段内容后打开百度网盘手机App,操作更方便哦
链接: 百度网盘 请输入提取码 提取码: yyhe 复制这段内容后打开百度网盘手机App,操作更方便哦
