EC25 不能獲取IP
各位好, 我用NanoPi R2C 連上EC25, 已安裝quectel-CM, 但不能獲取IP, 同一個硬件用在Window11是正常的 能連上網, Sim卡是可用的, 各位可否幫忙
root@NanoPi-R2C-Plus:~# quectel-CM &
[1] 1236
root@NanoPi-R2C-Plus:~# [09-15_07:38:20:363] WCDMA&LTE_QConnectManager_Linux&Android_V1.1.34
[09-15_07:38:20:364] quectel-CM profile[1] = (null)/(null)/(null)/0, pincode = (null)
[09-15_07:38:20:368] Find /sys/bus/usb/devices/2-1 idVendor=2c7c idProduct=0125
[09-15_07:38:20:368] Find /sys/bus/usb/devices/2-1:1.4/net/wwan0
[09-15_07:38:20:369] Find usbnet_adapter = wwan0
[09-15_07:38:20:369] Find /sys/bus/usb/devices/2-1:1.4/usbmisc/cdc-wdm0
[09-15_07:38:20:369] Find qmichannel = /dev/cdc-wdm0
root@NanoPi-R2C-Plus:~# [09-15_07:38:20:409] cdc_wdm_fd = 7
[09-15_07:38:20:502] Get clientWDS = 18
[09-15_07:38:20:534] Get clientDMS = 1
[09-15_07:38:20:566] Get clientNAS = 3
[09-15_07:38:20:598] Get clientUIM = 1
[09-15_07:38:20:630] Get clientWDA = 1
[09-15_07:38:20:662] requestBaseBandVersion EC20CEHCR06A06M1G
[09-15_07:38:20:758] requestGetSIMStatus SIMStatus: SIM_READY
[09-15_07:38:20:790] requestGetProfile[1] fpublic///0
[09-15_07:38:20:822] requestRegistrationState2 MCC: 454, MNC: 0, PS: Attached, DataCap: LTE
[09-15_07:38:20:854] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[09-15_07:38:20:918] requestRegistrationState2 MCC: 454, MNC: 0, PS: Attached, DataCap: LTE
[09-15_07:38:20:950] requestSetupDataCall WdsConnectionIPv4Handle: 0xe1768af0
[09-15_07:38:21:013] requestQueryDataCall IPv4ConnectionStatus: CONNECTED
[09-15_07:38:21:046] ifconfig wwan0 up
[09-15_07:38:21:068] busybox udhcpc -f -n -q -t 5 -i wwan0
udhcpc: started, v1.30.1
udhcpc: sending discover
udhcpc: no lease, failing
要看一下udhcpc调用的脚本,目前看模组网络是正常,dhcp 没有拿到地址, udhcpc 默认调用的脚本 default.script 用quectel-CM 拨号的default.script 脚本替换下,
