ec20 cefilg 使用电信4G卡能识别到卡但是连接不上网
我是按照官方提供的脚本配置的,输入at+cpin?可以识别到卡,物联网卡是确定能上网的
quectel-ppp
# /etc/ppp/peers/quectel-pppd
# Usage:root>pppd call quectel-pppd
#Modem path, like /dev/ttyUSB3,/dev/ttyACM0, depend on your module, default path is /dev/ttyUSB3
/dev/ttyS5 115200
#Insert the username and password for authentication, default user and password are test
user "ctnet@mycdma.cn" password "vnet.mobi"
# The chat script, customize your APN in this file
connect 'chat -s -v -f /etc/ppp/peers/quectel-chat-connect'
# The close script
disconnect 'chat -s -v -f /etc/ppp/peers/quectel-chat-disconnect'
# Hide password in debug messages
hide-password
# The phone is not required to authenticate
noauth
# Debug info from pppd
debug
# If you want to use the HSDPA link as your gateway
defaultroute
# pppd must not propose any IP address to the peer
noipdefault
# No ppp compression
novj
novjccomp
noccp
ipcp-accept-local
ipcp-accept-remote
local
# For sanity, keep a lock on the serial line
lock
modem
dump
nodetach
# Hardware flow control
nocrtscts
remotename 3gppp
ipparam 3gppp
ipcp-max-failure 30
# Ask the peer for up to 2 DNS server addresses
usepeerdns
把3gnet改为ctnet
# /etc/ppp/peers/quectel-chat-connect
ABORT "BUSY"
ABORT "NO CARRIER"
ABORT "NO DIALTONE"
ABORT "ERROR"
ABORT "NO ANSWER"
TIMEOUT 30
"" AT
OK ATE0
OK ATI;+CSUB;+CSQ;+CPIN?;+COPS?;+CGREG?;&D2
# Insert the APN provided by your network operator, default apn is 3gnet
OK AT+CGDCONT=1,"IP","CTNET",,0,0
OK ATD#777
CONNECT
以下是打印信息
root@cvt602-a:~# pppd call quectel-ppp &
[1] 579
pppd options in effect:
debug           # (from /etc/ppp/peers/quectel-ppp)
nodetach                # (from /etc/ppp/peers/quectel-ppp)
dump            # (from /etc/ppp/peers/quectel-ppp)
noauth          # (from /etc/ppp/peers/quectel-ppp)
user ctnet@mycdma.cn            # (from /etc/ppp/peers/quectel-ppp)
password ??????         # (from /etc/ppp/peers/quectel-ppp)
remotename 3gppp                # (from /etc/ppp/peers/quectel-ppp)
/dev/ttyS5              # (from /etc/ppp/peers/quectel-ppp)
115200          # (from /etc/ppp/peers/quectel-ppp)
lock            # (from /etc/ppp/peers/quectel-ppp)
connect chat -s -v -f /etc/ppp/peers/quectel-chat-connect               # (from /etc/ppp/peers/quectel-ppp)
disconnect chat -s -v -f /etc/ppp/peers/quectel-chat-disconnect         # (from /etc/ppp/peers/quectel-ppp)
nocrtscts               # (from /etc/ppp/peers/quectel-ppp)
modem           # (from /etc/ppp/peers/quectel-ppp)
hide-password           # (from /etc/ppp/peers/quectel-ppp)
novj            # (from /etc/ppp/peers/quectel-ppp)
novjccomp               # (from /etc/ppp/peers/quectel-ppp)
ipcp-accept-local               # (from /etc/ppp/peers/quectel-ppp)
ipcp-accept-remote              # (from /etc/ppp/peers/quectel-ppp)
ipparam 3gppp           # (from /etc/ppp/peers/quectel-ppp)
noipdefault             # (from /etc/ppp/peers/quectel-ppp)
ipcp-max-failure 30             # (from /etc/ppp/peers/quectel-ppp)
defaultroute            # (from /etc/ppp/peers/quectel-ppp)
usepeerdns              # (from /etc/ppp/peers/quectel-ppp)
noccp           # (from /etc/ppp/peers/quectel-ppp)
root@cvt602-a:~# abort on (BUSY)
abort on (NO CARRIER)
abort on (NO DIALTONE)
abort on (ERROR)
abort on (NO ANSWER)
timeout set to 30 seconds
send (AT^M)
expect (OK)
AT^M^M
 -- got it
send (ATE0^M)
expect (OK)
^M
ATE0^M^M
 -- got it
send (ATI;+CSUB;+CSQ;+CPIN?;+COPS?;+CGREG?;&D2^M)
expect (OK)
^M
^M
Quectel^M
EC20F^M
Revision: EC20CEFILGR06A09M1G^M
^M
SubEdition: V02^M
^M
+CSQ: 21,99^M
^M
+CPIN: READY^M
^M
+COPS: 0^M
^M
+CGREG: 0,0^M
^M
 -- got it
send (AT+CGDCONT=1,"IP","CTNET",,0,0^M)
expect (OK)
^M
^M
 -- got it
send (ATD#777^M)
expect (CONNECT)
^M
^M
CONNECT
 -- got it
Script chat -s -v -f /etc/ppp/peers/quectel-chat-connect finished (pid 580), status = 0x0
Serial connection established.
using channel 2
Using interface ppp0
Connect: ppp0 <--> /dev/ttyS5
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x62f61f6d> <pcomp> <accomp>]
rcvd [LCP ConfReq id=0x1f <asyncmap 0x0> <auth chap MD5> <magic 0xd1480e78> <pcomp> <accomp>]
sent [LCP ConfAck id=0x1f <asyncmap 0x0> <auth chap MD5> <magic 0xd1480e78> <pcomp> <accomp>]
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x62f61f6d> <pcomp> <accomp>]
rcvd [LCP DiscReq id=0x20 magic=0xd1480e78]
rcvd [CHAP Challenge id=0x1 <e45c65eebd35ac0cfd6ee823be93fa08>, name = "UMTS_CHAP_SRVR"]
sent [CHAP Response id=0x1 <8479f066effc0d8ac5decd5a9e6e45e6>, name = "ctnet@mycdma.cn"]
rcvd [CHAP Success id=0x1 ""]
CHAP authentication succeeded
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
IPCP: timeout sending Config-Requests
sent [LCP TermReq id=0x2 "No network protocols running"]
sent [LCP TermReq id=0x3 "No network protocols running"]
Connection terminated.
abort on (ERROR)
Sending break to the modem
send (+++^M)
send (+++^M)
send (+++^M)
Goodbay
Script chat -s -v -f /etc/ppp/peers/quectel-chat-disconnect finished (pid 595), status = 0x0
Serial link disconnected.
Modem hangup
你好
从log看 模块没有注册上4G ,需要确认SIM卡否正常 可以更换成手机电信卡对比
