切换成RNDIS,故障依旧。
模块EC20CEFILGR06A07M1G能够获取到内网IP,但无法访问外网
模块EC20CEHCLGR06A05M1G能够正常访问
同时遇到新的问题,两个模块的AT端口/dev/ttyUSB2都消失了,所以现在也无法通过AT端口看状态了,这个要怎么恢复?通过lsusb可以看到2c7c 0125的设备能被识别到,dmesg里也没有什么特别有意义的异常信息输出
lsusb:
Bus 001 Device 003: ID 0bda:c82c
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 1a40:0201
Bus 002 Device 001: ID 1d6b:0003
Bus 001 Device 004: ID 2c7c:0125
dmesg:
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
xhci-hcd 100e0000.xhci_0: xHCI Host Controller
xhci-hcd 100e0000.xhci_0: new USB bus registered, assigned bus number 1
xhci-hcd 100e0000.xhci_0: hcc params 0x0220fe6c hci version 0x110 quirks 0x20010010
xhci-hcd 100e0000.xhci_0: irq 30, io mem 0x100e0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
xhci-hcd 100e0000.xhci_0: new USB bus registered, assigned bus number 2
usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
hub 2-0:1.0: USB hub found
hub 2-0:1.0: hub can’t support USB3.0
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
hibvt_rtc 12080000.rtc: rtc core: registered 12080000.rtc as rtc0
rndis_host 1-1.2:1.0 usb0: register ‘rndis_host’ at usb-100e0000.xhci_0-1.2, RNDIS device, e6:db:44:f9:da:a5
option 1-1.2:1.2: GSM modem (1-port) converter detected
usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
option 1-1.2:1.3: GSM modem (1-port) converter detected
usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
