RM500Q-GL测速速度慢
RM500Q-GL在openwrt上面porting驱动后可以正常上网,但是网络测速时速度一直上不去。
普通的中国移动SIM卡下载最高只能上到20Mbps,下载只有10Mbps不到。(www.speedtest.cn)
这个现象要从哪里查起?modem内部有没有什么参数可以调整?是不是没有连接到5G,而是接的3G/4G?
正常情况下应该起码100Mbps以上,最高可以达到500Mbps。(RM500Q-GL通过USB3.0接入)
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-mtk/1p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=option, 5000M
|__ Port 1: Dev 2, If 1, Class=Vendor Specific Class, Driver=option, 5000M
|__ Port 1: Dev 2, If 2, Class=Vendor Specific Class, Driver=option, 5000M
|__ Port 1: Dev 2, If 3, Class=Vendor Specific Class, Driver=option, 5000M
|__ Port 1: Dev 2, If 4, Class=Vendor Specific Class, Driver=qmi_wwan_q, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-mtk/2p, 480M
cat /sys/kernel/debug/usb/devices
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 4.04
S: Manufacturer=Linux 4.4.198 xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=1e1c0000.usb
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=5000 MxCh= 0
D: Ver= 3.20 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1
P: Vendor=2c7c ProdID=0800 Rev= 4.14
S: Manufacturer=Quectel
S: Product=RM500Q-GL
S: SerialNumber=85e399e2
C:* #Ifs= 5 Cfg#= 1 Atr=a0 MxPwr=896mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=30 Driver=option
E: Ad=81(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=82(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=84(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=87(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=86(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan_q
E: Ad=88(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=8e(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E: Ad=0f(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 4.04
你好,想問下你是否解決了呢?我也遇到了類似問題,你可以先確定你是否採用的是 5G NR,同時嘗試更換驅動方式,因為我發現不同的驅動結果是不同的
还没有解决。我们这边采用的应该是USB 3.0的接入方式。我也听说用PCIE接口更好,但是好像没有PCIE的驱动。
你那边已经解决了吗?帮忙提供一些方法,确认或者修改的方法都行。
目前我这边尝试做了一些修改,速度能够上到150Mpbs,但是客户那边有别家的,能够上到500Mbps以上。
都是用的MT7621+RM500Q
不好意思刚看到,目前我这边用手机卡在 rsrp 很好的情况下,速度也只能到 150Mbps。我们采用的也是 USB 3.0 接口,但是 3.0 的硬件速度按道理是能达到 500Mbps 的就像你 lsusb -t 一样,不知道你是否实际侧过模组和 CPU 之间的 usb 速率?另外不知道能够请教你做的修改具体是哪方面的呢?我这边只对比过不同驱动方式是会存在差别的,不过 qmi_wan 和 NCM/ECM 区别不是很大?
你提到的别家的,上到 500Mbps,是否是因为不是使用的公网卡?或者是在实验室环境?
另外建议使用 speedtest.net 而不使用 cn
可以帮我弄一下吗,我也遇到的了相同的问题
