EC600N,固件 EC600NCNLAR03A11M08。重新注册前已配置 CGDCONT 为 IPV4V6、QICSGP 类型为 3。激活成功,但 QIACT 和 CGPADDR 都只有 IPv4,连接 IPv6 返回 572。这是固件不支持还是sim卡不支持呀?
[2026-11-18 12:06:39] [IPv6-INIT-TEST] BEGIN: re-register IPv4v6 before NTP and center connections
[2026-11-18 12:06:44] [IPv6-DIAG] TX: AT+CFUN=0
[2026-11-18 12:06:44] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:06:44] OK
[2026-11-18 12:06:44] [IPv6-DIAG] TX: AT+CGDCONT=1,“IPV4V6”,“CMMTMHJKJ.FJ”
[2026-11-18 12:06:44] [IPv6-DIAG] TX: AT+QICSGP=1,3,“CMMTMHJKJ.FJ”,“”,“”,1
[2026-11-18 12:06:46] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:06:46] OK
[2026-11-18 12:06:46] [IPv6-DIAG] TX: AT+CFUN=1
[2026-11-18 12:06:46] [IPv6-INIT-TEST] CONFIG ret=0, RF resume ret=0
[2026-11-18 12:06:48] EC600N:Network Register Success, RSSI:25
[2026-11-18 12:06:49] EC600N:Generated Serial Number:0x000
[2026-11-18 12:06:50] EC600 PDP1:
[2026-11-18 12:06:50] +QIACT: 1,1,3,“10.4.231.173”
[2026-11-18 12:06:50] OK
[2026-11-18 12:06:50] [IPv6-INIT-TEST] PDP1 ret=0; addresses BEFORE NTP/center connections:
[2026-11-18 12:06:50] [IPv6-DIAG] TX: AT+QICSGP=1
[2026-11-18 12:06:50] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:06:50] +QICSGP: 3,“CMMTMHJKJ.FJ”,“”,“”,1
[2026-11-18 12:06:50] [IPv6-DIAG] TX: AT+CGDCONT?
[2026-11-18 12:06:51] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:06:51] +CGDCONT: 1,“IPV4V6”,“CMMTMHJKJ.FJ”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0,0,0
[2026-11-18 12:06:51] +CGDCONT: 2,“IP”,“CMMTMHJKJ.FJ”,“0.0.0.0”,0,0,0,0,0,0
[2026-11-18 12:06:51] +CGDCONT: 3,“IP”,“xjwlw03s.xam2mapn”,“0.0.0.0”,0,0,0,0,0,0
[2026-11-18 12:06:51] OK
[2026-11-18 12:06:51] [IPv6-DIAG] TX: AT+QIACT?
[2026-11-18 12:06:51] +QIACT: 1,1,3,“10.4.231.173”
[2026-11-18 12:06:51] [IPv6-DIAG] TX: AT+CGPADDR=1
[2026-11-18 12:06:52] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:06:52] +CGPADDR: 1,“10.4.231.173”
[2026-11-18 12:06:52] OK
[2026-11-18 12:06:52] [IPv6-INIT-TEST] END
接下来是
[2026-11-18 12:07:13] [IPv6-BOOT-TEST] BEGIN [2a05:d018:1f16:263:a84f:c2:64c3:481f]:7 (runtime only; saved config retained)
[2026-11-18 12:07:13] [IPv6-DIAG] TX: AT+QICSGP=1
[2026-11-18 12:07:13] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:07:13] +QICSGP: 3,“CMMTMHJKJ.FJ”,“”,“”,1
[2026-11-18 12:07:13] OK
[2026-11-18 12:07:13] [IPv6-DIAG] TX: AT+CGDCONT?
[2026-11-18 12:07:14] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:07:14] +CGDCONT: 1,“IPV4V6”,“CMMTMHJKJ.FJ”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0,0,0
[2026-11-18 12:07:14] +CGDCONT: 2,“IP”,“CMMTMHJKJ.FJ”,“0.0.0.0”,0,0,0,0,0,0
[2026-11-18 12:07:14] +CGDCONT: 3,“IP”,“xjwlw03s.xam2mapn”,“0.0.0.0”,0,0,0,0,0,0
[2026-11-18 12:07:14] OK
[2026-11-18 12:07:14] [IPv6-DIAG] TX: AT+QIACT?
[2026-11-18 12:07:14] +QIACT: 1,1,3,“10.4.231.173”
[2026-11-18 12:07:14] [IPv6-DIAG] TX: AT+CGPADDR=1
[2026-11-18 12:07:16] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:07:16] +CGPADDR: 1,“10.4.231.173”
[2026-11-18 12:07:16] OK
[2026-11-18 12:07:16] Second network: opening IPv6 [2a05:d018:1f16:263:a84f:c2:64c3:481f]:7
[2026-11-18 12:07:17] EC600 QIOPEN id=1 ret=-1:
[2026-11-18 12:07:17] OK
[2026-11-18 12:07:17] +QIOPEN: 1,572
[2026-11-18 12:07:17] [IPv6-DIAG] QIOPEN result=572 (modem result; not an MCU wait timeout)
[2026-11-18 12:07:17] [IPv6-DIAG] TX: AT+QIGETERROR
[2026-11-18 12:07:17] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:07:17] +QIGETERROR: 572,operation not allowed
[2026-11-18 12:07:19] 1 TCP Connection:Port Open Failed,RET:-1
[2026-11-18 12:07:19] Second network: opening IPv6 [2a05:d018:1f16:263:a84f:c2:64c3:481f]:7
[2026-11-18 12:07:19] EC600 QIOPEN id=1 ret=-1:
[2026-11-18 12:07:19] OK
[2026-11-18 12:07:19] +QIOPEN: 1,572
[2026-11-18 12:07:19] [IPv6-DIAG] QIOPEN result=572 (modem result; not an MCU wait timeout)
[2026-11-18 12:07:20] [IPv6-DIAG] TX: AT+QIGETERROR
[2026-11-18 12:07:20] [IPv6-DIAG] RX ret=0:
[2026-11-18 12:07:20] +QIGETERROR: 572,operation not allowed
[2026-11-18 12:07:20] OK
[2026-11-18 12:07:21] 1 TCP Connection:Port Open Failed,RET:-1
[2026-11-18 12:07:21] [IPv6-BOOT-TEST] OPEN FAILED ret=-1
