root@curvaturezero:~# [06-09_11:03:05:486] QConnectManager_Linux_V1.6.2[06-09_11:03:05:488] Find /sys/bus/usb/devices/1-1.1 idVendor=0x2c7c idProduct=0x125,bus=0x001,find qmichannel = /dev/cdc-wdmo[06-0911:03:05:488]AutoAuto find usbnet_adapter = wwano[06-0911:03:05:488]06-0911:03:08:488]netcard driver = qmi_wwan, driver version = 6.12.45[06-0911:03:08:488]Modem works in QMI mode/proc/8310/fd/7 → /dev/cdc-wdmo[06-0911:03:08:493][06-0911:03:08:493]/proc/8310/exe → /usr/bin/quectel-cm06-0911:03:10:495]cdc wdm fd =06-0911:03:10:589]Get clientWDS =7[06-0911:03:10:6221Get clientDMS=106-0911:03:10:653]Get clientNAS2[06-0911:03:10:685]Get clientUIM106-0911:03:10:717]Get clientWDA =[06-0911:03:10:749]requestBaseBandVersion EM05CEFCR06A04M1G_ND[06-0911:03:10:877]requestGetSIMStatus SIMStatus: SIM_READYCMD=SIMSTATUS,STATE=2[06-09 11:03:10:909] requestGetProfile[1] bdjjzd.grevpdn.he///0/IPV4requestRegistrationState2 MCC: 460, MNC: 11, PS: Detached, DataCap: UNKNOW[06-0911:03:10:974][06-09_11:03:11:006] requestGetSignalInfo LTE: RSSI -49 dBm, RSRQ -7 dB, RSRP -76 dBm, SNR 26.8CMD=SIGNALINFO,MODE=LTE,RSSI=-49,RSRQ=-7[06-09_11:03:11:037] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTEDCommand failed: Not foundCommand failed: Not found[06-09 11:03:11:966] QmiWwanThread exit[06-0911:03:11:967] qmi main exit
@orkyiq 日志:[06-09 11:03:10:909] requestGetProfile[1] bdjjzd.grevpdn.he///0/IPV4
- 联通普通物联网 / 手机卡标准 APN:
3gnet; - 你当前 APN 字符串异常、不是运营商合法 APN,模组无法建立 PDP 上下文,PS 附着失败,QMI 创建数据通道时报
Not found,进程退出。可以通过:AT+CGDCONT?指令查看一下APN,确认下有没有3gnet
