求一份 ubuntu 22.04 下 EM05CNFDR08A03M1G_ND 的最新版本驱动
Apr 20 23:17:42 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (home → unknown) Apr 20 23:17:42 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → registering) Apr 20 23:17:42 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (registering → home) Apr 21 10:50:50 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (home → unknown) Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] network reject indication received Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] service domain: ps Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] radio interface: lte Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] reject cause: implicitly-detached Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0/bearer1] verbose call end reason (3,1056): [cm] lrrc-connection-establishment-failure-timer-expired Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] state changed (connected → enabled) Apr 21 10:50:55 td-Default-string NetworkManager[588]: [1776739855.5190] device (cdc-wdm0): state change: activated → failed (reason ‘modem-no-carrier’, sys-iface-state: ‘managed’) Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0/bearer1] connection #1 finished: duration 511863s, tx: 6957587078 bytes, rx: 1566728755 bytes Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] simple connect started… Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] simple connect state (6/10): register Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] network reject indication received Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] service domain: cs-ps Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] radio interface: lte Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] reject cause: no-suitable-cells-in-location-area Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → searching) Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] state changed (enabled → searching) Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (searching → unknown) Apr 21 10:50:55 td-Default-string ModemManager[681]: [modem0] state changed (searching → enabled) Apr 21 10:50:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → searching) Apr 21 10:50:56 td-Default-string ModemManager[681]: [modem0] state changed (enabled → searching) Apr 21 10:50:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (searching → unknown) Apr 21 10:50:56 td-Default-string ModemManager[681]: [modem0] state changed (searching → enabled) Apr 21 10:50:59 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → searching) Apr 21 10:50:59 td-Default-string ModemManager[681]: [modem0] state changed (enabled → searching) Apr 21 10:50:59 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (searching → unknown) Apr 21 10:50:59 td-Default-string ModemManager[681]: [modem0] state changed (searching → enabled) Apr 21 10:50:59 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → searching) Apr 21 10:50:59 td-Default-string ModemManager[681]: [modem0] state changed (enabled → searching) Apr 21 10:51:02 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (searching → unknown) Apr 21 10:51:02 td-Default-string ModemManager[681]: [modem0] state changed (searching → enabled) Apr 21 10:51:05 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → searching) Apr 21 10:51:05 td-Default-string ModemManager[681]: [modem0] state changed (enabled → searching) Apr 21 10:51:05 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (searching → unknown) Apr 21 10:51:05 td-Default-string ModemManager[681]: [modem0] state changed (searching → enabled) Apr 21 10:51:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → searching) Apr 21 10:51:08 td-Default-string ModemManager[681]: [modem0] state changed (enabled → searching) Apr 21 10:51:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (searching → unknown) Apr 21 10:51:08 td-Default-string ModemManager[681]: [modem0] state changed (searching → enabled) Apr 21 10:51:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:51:11 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:51:32 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:51:44 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:51:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:52:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:52:20 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:52:32 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:52:44 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:52:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:53:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:53:20 td-Default-string ModemManager[681]: [modem0] simple connect started… Apr 21 10:53:20 td-Default-string ModemManager[681]: [modem0] simple connect state (6/10): register Apr 21 10:53:20 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:53:32 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:53:44 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:53:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:54:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:54:20 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:54:32 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:54:44 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:54:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:55:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:55:20 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:55:32 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:55:44 td-Default-string ModemManager[681]: [modem0] simple connect started… Apr 21 10:55:44 td-Default-string ModemManager[681]: [modem0] simple connect state (6/10): register Apr 21 10:55:44 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:55:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:56:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:56:20 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:56:32 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:56:44 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:56:56 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:57:08 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:57:13 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:57:18 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:57:18 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:57:20 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:57:20 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown) Apr 21 10:57:23 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (unknown → idle) Apr 21 10:57:23 td-Default-string ModemManager[681]: [modem0] 3GPP registration state changed (idle → unknown)
当前模组用在工控机上,总是偶发性断网,网上搜了下说是版本要更新,麻烦提供下最新版本,谢谢
邮箱:old_tiger@126.com
1, 是注网问题还是拨号工具问题还得再看看. 建议先查询一下信号质量如何:
AT+CSQ
AT+QCSQ 如果信号很差建议检查一下天线连接
2, 我付上了最新的usb驱动和QMI_WWAN网卡驱动, 请在下面的onedrive链接获取.
driver
3, 关于拨号工具, 有兴趣您也可以尝试一下quectel的QconnectManager工具. 我付上了参考步骤, 工具您也可以从上面的link获取.
RM520N-Ubuntu-qmi_datacall_demo.pdf (1.4 MB)
