在Linux5.10的Ubuntu22.04系统里面,fme164q对应的固件驱动都安装完成;但是在连接WIFI的时候,系统直接卡死,网络也不能ping通,串口打印的内容为:
[ 505.497942] wlan: Loading driver v5.2.0.220S.093
[ 505.546184] [bhi_probe] jtagid:0x1019b0e1
[ 505.562491] patch-1: clear rx-vec, bhi_base as 0x0000000000000000
root@cstipc:/usr/bin# [ 506.388139] cnss: cnss_fw_ready_hdlr 647
[ 506.403757] [kworke][0x1e2f0f53][09:10:16.555432] wlan: [325:E:TXRX] hif_print_ hal_shadow_register_cfg: num_config 28
[ 506.431436] [kworke][0x1e2f7b71][09:10:16.583109] wlan: [325:E:QDF] cds_get_c ontext: Module ID 66 context is Null (via hdd_update_ol_config)
[ 506.435383] [kworke][0x1e2f8add][09:10:16.587057] wlan: [325:E:QDF] cds_get_c ontext: Module ID 66 context is Null (via cds_open)
[ 506.444691] [kworke][0x1e2faf3a][09:10:16.596366] wlan: [325:F:WMA] WMA → wmi unified_attach - success
[ 506.469057] [kworke][0x1e300e68][09:10:16.620732] wlan: [325:E:QDF] htc_wait_ta rget: Target Ready! TX resource : 1 size:2176, MaxMsgsPerHTCBundle = 1
[ 506.469066] [kworke][0x1e300e70][09:10:16.620740] wlan: [325:E:QDF] htc_setup_t arget_buffer_assignments: SVS Index : 1 TX : 0x100 : alloc:1
[ 506.469092] [kworke][0x1e300e8c][09:10:16.620768] wlan: [325:E:DP] dp_srng_get str_from_hal_ring_type: Invalid ring type
[ 506.469100] [kworke][0x1e300e94][09:10:16.620776] wlan: [325:E:DP] dp_prealloc get_coherent: unable to allocate memory for ring type tcl_cmd_credit (6) size 1638 4
[ 506.469119] [kworke][0x1e300ea7][09:10:16.620795] wlan: [325:E:DP] dp_prealloc get_coherent: unable to allocate memory for ring type tcl_status (7) size 16384
[ 506.469126] [kworke][0x1e300eae][09:10:16.620802] wlan: [325:E:DP] dp_prealloc get_coherent: unable to allocate memory for ring type Reo_reinject (2) size 16384
[ 506.469138] [kworke][0x1e300eba][09:10:16.620814] wlan: [325:E:DP] dp_prealloc get_coherent: unable to allocate memory for ring type Reo_cmd (3) size 16384
[ 506.469240] [kworke][0x1e300f20][09:10:16.620916] wlan: [325:E:DP] dp_prealloc_ get_coherent: unable to allocate memory for ring type Reo_status (4) size 16384
[ 506.471852] [kworke][0x1e301954][09:10:16.623529] wlan: [325:E:DP] dp_prealloc_ get_coherent: unable to allocate memory for ring type Rxdma_monitor_status (17) si ze 16384
[ 506.472357] [kworke][0x1e301b4d][09:10:16.624033] wlan: [325:E:DP] dp_prealloc_ get_coherent: unable to allocate memory for ring type Rxdma_monitor_status (17) si ze 16384
[ 506.472695] [kworke][0x1e301c9c][09:10:16.624368] wlan: [325:E:DP] dp_prealloc_ get_coherent: unable to allocate memory for ring type Rxdma_buf (14) size 16384
[ 506.472755] [kworke][0x1e301cdb][09:10:16.624432] wlan: [325:E:DP] dp_prealloc_ get_coherent: unable to allocate memory for ring type Rxdma_buf (14) size 16384
[ 506.481962] [kworke][0x1e3040d0][09:10:16.633636] wlan: [292:E:QDF] copy_fw_abi _version_tlv: copy_fw_abi_version_tlv: INIT_CMD version: 1, 0, 0x5f414351, 0x4c4d, 0x0, 0x0
[ 506.753477] [kworke][0x1e34656d][09:10:16.905153] wlan: [292:E:QDF] ready_extra ct_init_status_tlv: ready_extract_init_status_tlv:0
[ 506.753938] [kworke][0x1e34673a][09:10:16.905614] wlan: [292:E:CFR] wlan_cfr_pd ev_open: cfr is disabled
[ 506.754093] [kworke][0x1e3467d5][09:10:16.905769] wlan: [292:E:QDF] dp_peer_map _attach_wifi3: dp_peer_map_attach_wifi3 max_peers 83, max_ast_index: 144
[ 506.754093]
[ 506.755137] [kworke][0x1e346be9][09:10:16.906812] wlan: [325:E:WMI] send_action _oui_cmd_tlv: Invalid action id
[ 506.755142] [kworke][0x1e346bed][09:10:16.906818] wlan: [325:E:action_oui] ucfg action_oui_send: Failed to send: 7
[ 506.755407] [kworke][0x1e346cf7][09:10:16.907083] wlan: [325:E:TXRX] dp_rxdma_r ing_config: DBS enabled max_mac_rings 2
[ 506.755410] [kworke][0x1e346cfa][09:10:16.907086] wlan: [325:E:TXRX] dp_rxdma_r ing_config: pdev_id 0 max_mac_rings 2
[ 506.755413] [kworke][0x1e346cfc][09:10:16.907089] wlan: [325:E:TXRX] dp_rxdma_r ing_config: mac_id 0
[ 506.755442] [kworke][0x1e346d1a][09:10:16.907118] wlan: [325:E:TXRX] dp_rxdma_r ing_config: mac_id 1
[ 506.755721] [kworke][0x1e346e30][09:10:16.907397] wlan: [325:E:REGULATORY] reg freq_width_to_chan_op_class: no op class for frequency 5660
[ 506.756114] cnss_utils: WLAN MAC address is not set, type 0
[ 519.979843] [soft_i][0x1efe36e9][09:10:30.131517] wlan: [0:E:DP] dp_peer_unlink ast_entry: NULL peer
[ 519.980022] [schedu][0x1efe379c][09:10:30.131696] wlan: [3140:E:DP] dp_tx_flow pool_vdev_unmap: invalid vdev_id 0
[ 519.980036] [schedu][0x1efe37aa][09:10:30.131710] wlan: [3140:E:DP] dp_tx_delet e_flow_pool: flow pool either not created or alread deleted
[ 550.123102] [schedu][0x20ca2a07][09:11:00.274778] wlan: [3140:E:REGULATORY] reg _chan_band_to_freq: Invalid channel 0
[ 551.350258] [schedu][0x20dce399][09:11:01.501933] wlan: [3140:E:PE] lim_process _mlm_auth_cnf: Auth Failure occurred
[ 551.725520] [schedu][0x20e29d76][09:11:01.877194] wlan: [3140:E:HDD] hdd_associ ation_completion_handler: wlan0(vdevid-0): connection failed with 50:0f:f5:17:ec:5 1 result: 3 and Status: 7
[ 551.725843] [schedu][0x20e29eb9][09:11:01.877517] wlan: [3140:E:HDD] hdd_associ ation_completion_handler: wlan0(vdevid-0): connection failed with 50:0f:f5:17:ec:5 1 result: 1 and Status: 9
[ 551.725957] [schedu][0x20e29f2b][09:11:01.877631] wlan: [3140:E:HDD] hdd_associ ation_completion_handler: send connect failure to nl80211: for bssid 50:0f:f5:17:e c:51 result: 1 and Status: 9 reasoncode: 65530
[ 551.726106] [wpa_su][0x20e29fc2][09:11:01.877782] wlan: [1093:E:OSIF] wlan_cfg8 0211_mc_cp_stats_get_station_stats: peer is null
[ 551.726113] [wpa_su][0x20e29fc9][09:11:01.877789] wlan: [1093:E:HDD] hdd_get_st ation_info_ex: wlan_hdd_get_station_stats fail
[ 558.456637] [soft_i][0x214952e4][09:11:08.608312] wlan: [0:E:DP] dp_peer_unlink ast_entry: NULL peer
[ 558.456820] [schedu][0x2149539a][09:11:08.608494] wlan: [3140:E:DP] dp_tx_flow pool_vdev_unmap: invalid vdev_id 0
[ 558.456833] [schedu][0x214953a8][09:11:08.608508] wlan: [3140:E:DP] dp_tx_delet e_flow_pool: flow pool either not created or alread deleted
[ 565.341410] [schedu][0x21b2608a][09:11:15.493086] wlan: [3140:E:REGULATORY] reg _chan_band_to_freq: Invalid channel 0
[ 566.502238] [schedu][0x21c41707][09:11:16.653915] wlan: [3140:E:PE] lim_process _mlm_auth_cnf: Auth Failure occurred
[ 570.530172] [schedu][0x22018d24][09:11:20.681848] wlan: [3140:F:WMA] wma_hold_r eq_timer: request 4131 is timed out for vdev_id - 0
[ 570.530178] [schedu][0x22018d2a][09:11:20.681854] wlan: [3140:E:WMA] wma_hold_r eq_timer: wma delete peer for del bss req timed out
[ 570.530186] [schedu][0x22018d30][09:11:20.681860] wlan: [3140:E:WMA] wma_trigge r_recovery_assert_on_fw_timeout: WMA_DELETE_STA_REQ timed out, triggering recovery
[ 570.530314] [schedu][0x22018db3][09:11:20.681991] wlan: [3140:E:SME] csr_roam_j oin_rsp_processor: disconnect is pending, complete roam
[ 570.530440] [schedu][0x22018e31][09:11:20.682116] wlan: [3140:E:HDD] hdd_associ ation_completion_handler: wlan0(vdevid-0): connection failed with 50:0f:f5:17:ec:5 1 result: 3 and Status: 7
[ 570.530546] [schedu][0x22018e9b][09:11:20.682223] wlan: [3140:E:HDD] hdd_associ ation_completion_handler: wlan0(vdevid-0): connection failed with 50:0f:f5:17:ec:5 1 result: 1 and Status: 9
[ 571.118342] [schedu][0x220a86ae][09:11:21.270018] wlan: [3140:E:WMA] wma_find_r emove_req_msgtype: target request not found for vdev_id 0 type 4131
[ 571.250186] [fw_paging_dump] to create file:/var/crash/2026-04-22-09-11-21-pagi ng.bin
[ 571.250383] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x00000000cc2a65a2, size: 0x80000
[ 571.283714] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x000000002474aa1e, size: 0x80000
[ 571.290598] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x00000000373ebf26, size: 0x80000
[ 571.298388] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x00000000fa51face, size: 0x80000
[ 571.304464] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x0000000067309af5, size: 0x80000
[ 571.311287] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x0000000087f4c10c, size: 0x80000
[ 571.317326] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x000000000d03742a, size: 0x80000
[ 571.319296] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x00000000064b1ab5, size: 0x80000
[ 571.320367] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x00000000bcbe6fa1, size: 0x80000
[ 571.321447] [fw_paging_dump] to write file:/var/crash/2026-04-22-09-11-21-pagin g.bin, mem: 0x0000000062c0342c, size: 0x80000
[ 571.347653] [fw_remote_mem_dump] to write file:/var/crash/2026-04-22-09-11-21-r emote.bin, mem: 0x00000000a17c6d27, size: 0x67c000
[ 571.391217] [firmware_dump] to create file:/var/crash/2026-04-22-09-11-21-fwsra m.bin
[ 571.391462] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x00000000f23ce6aa, size: 0x80000
[ 571.392450] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x000000006ac91763, size: 0x80000
[ 571.393420] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x0000000090bc6584, size: 0x80000
[ 571.394380] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x000000007f6e2d5e, size: 0x80000
[ 571.395287] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x00000000b296e68d, size: 0x80000
[ 571.396157] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x00000000f4a75d2f, size: 0x80000
[ 571.399645] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x0000000029c74659, size: 0x80000
[ 571.400552] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x000000000e1813d5, size: 0x80000
[ 571.401456] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x0000000077a6a7c1, size: 0x80000
[ 571.402846] [firmware_dump] to write file:/var/crash/2026-04-22-09-11-21-fwsram .bin, mem: 0x00000000b934080f, size: 0x90
[ 571.425016] [dump_fw_to_file] version:0x1, size: 0x188
[ 571.425023] [extract_fw_mem_dump] to create file:/var/crash/2026-04-22-09-11-21 -Q6-SRAM.bin
[ 571.425277] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x00000000f23ce6aa, size: 0x80000
[ 571.425280] [extract_fw_mem_dump] mem: 0x00000000a3b12ec2, size: 0x7fe78
[ 571.426374] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x000000006ac91763, size: 0x80000
[ 571.426377] [extract_fw_mem_dump] mem: 0x000000006ac91763, size: 0x80000
[ 571.427339] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x0000000090bc6584, size: 0x80000
[ 571.427342] [extract_fw_mem_dump] mem: 0x0000000090bc6584, size: 0x80000
[ 571.428240] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x000000007f6e2d5e, size: 0x80000
[ 571.428243] [extract_fw_mem_dump] mem: 0x000000007f6e2d5e, size: 0x80000
[ 571.429315] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x00000000b296e68d, size: 0x80000
[ 571.429317] [extract_fw_mem_dump] mem: 0x00000000b296e68d, size: 0x80000
[ 571.431815] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x00000000f4a75d2f, size: 0x80000
[ 571.431819] [extract_fw_mem_dump] mem: 0x00000000f4a75d2f, size: 0x80000
[ 571.432734] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x0000000029c74659, size: 0x80000
[ 571.432737] [extract_fw_mem_dump] mem: 0x0000000029c74659, size: 0x80000
[ 571.433641] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SRAM.bin, mem: 0x000000000e1813d5, size: 0x80000
[ 571.433643] [extract_fw_mem_dump] mem: 0x000000000e1813d5, size: 0x188
[ 571.450712] [extract_fw_mem_dump] to create file:/var/crash/2026-04-22-09-11-21 -ETB_SOC.bin
[ 571.450902] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x00000000f23ce6aa, size: 0x80000
[ 571.450906] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x000000006ac91763, size: 0x80000
[ 571.450907] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x0000000090bc6584, size: 0x80000
[ 571.450909] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x000000007f6e2d5e, size: 0x80000
[ 571.450910] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x00000000b296e68d, size: 0x80000
[ 571.450911] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x00000000f4a75d2f, size: 0x80000
[ 571.450913] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x0000000029c74659, size: 0x80000
[ 571.450914] [extract_fw_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- ETB_SOC.bin, mem: 0x000000000e1813d5, size: 0x80000
[ 571.450916] [extract_fw_mem_dump] mem: 0x00000000620317d1, size: 0x4000
[ 571.452024] [extract_fw_mem_dump] to create file:/var/crash/2026-04-22-09-11-21 ite file:/var/crash/2026-04-22-09-11-21-Q6-SFR_mem_dump] to write file:/var/crash/ 2026-04-22-09-11-21-Q6-SFR_mem_dump] to write file:/var/crash/2026-04-22-09-11-21- Q6-SFR_mem_dump] to write file:/var/crash/2026-04-22-09-11-21-Q6-SFR_mem_dump] to write file:/var/crash/2026-04-22-09-11-21-Q6-SFR_mem_dump] to write file:/var/cras h/2026-04-22-09-11-21-Q6-SFR.bin, mem: 0x00000000f23ce6aa, size: 0x80000
这是连接WiFi后的打印
后续就是一直打印空白,请问我是什么地方导致的错误?
