您好,请提供一份包含以下信息的AT手册,谢谢!我的Quectel设备型号是RG530
+QNWCFG: “lte_cdrx”,(0,1),(0,1)
+QNWCFG: “nr5g_cdrx”,(0,1)
+QNWCFG: “csi_ctrl”,(0,1),(0,1)
+QNWCFG: “lte_csi”
+QNWCFG: “nr5g_csi”
+QNWCFG: “lte_cell_id”
+QNWCFG: “nr5g_cell_id”
+QNWCFG: “lte_csi_ext”,(0,1)
+QNWCFG: “nr5g_csi_ext”,(0,1)
+QNWCFG: “lte_tx_pwr”,(0,1)
+QNWCFG: “nr5g_tx_pwr”,(0,1)
+QNWCFG: “wcdma_cqi”
+QNWCFG: “up/down”,(1-60)
+QNWCFG: “data_path”,(0,1)
+QNWCFG: “dss_enable”,(0,1)
+QNWCFG: “lte_dl_tx_mode”
+QNWCFG: “nr5g_ulMCS”,(0,1)
+QNWCFG: “nr5g_dlMCS”,(0,1)
+QNWCFG: “nr5g_pusch_data”,(0,1)
+QNWCFG: “lapi”,(0,1)
+QNWCFG: “nr5g_meas_info”,(0,1)
+QNWCFG: “lte_time_advance”,(0,1)
+QNWCFG: “nr5g_time_advance”,(0,1)
+QNWCFG: “clr_rplmn”
+QNWCFG: “dis_rplmnact”,(0,1)
+QNWCFG: “lte_ambr”
+QNWCFG: “nr5g_ambr”
+QNWCFG: “disable_lte_ca”,(0,1)
+QNWCFG: “disable_nr_ca”,(0,1)
+QNWCFG: “dis_4mimo_enable”,(0,1)
+QNWCFG: “nr5g_4mimo_enable”,(0,1)
+QNWCFG: “nr5g_ulTBsize”,(0,1),(1-100)
+QNWCFG: “encryp_alg_support”
+QNWCFG: “integ_alg_support”
+QNWCFG: “data_roaming”,(0,1)
+QNWCFG: “nr5g_earfcn_lock”,(0-32),<EARFCN_list>
+QNWCFG: “lte_earfcn_lock”,(0-2),<EARFCN_list>
+QNWCFG: “event_a3_offset”,(0,1),(0-255)
+QNWCFG: “used_algo”,(0,1)
+QNWCFG: “nr5g_pref_freq_list”,(0-32),<EARFCN_list>
+QNWCFG: “lte_pref_freq_list”,(0-32),<EARFCN_list>
+QNWCFG: “ehplmn_config”,(0-20),<ehplmn_list>
+QNWCFG: “nr5g_mimo”,(0,1)
+QNWCFG: “ctrl_plane_dly”,(0,1)
+QNWCFG: “rrc_state”,(0,1)
+QNWCFG: “ssb_beam_id”,(0,1)
+QNWCFG: “ul_data_path”,(0,1)
+QNWCFG: “lte_ulMCS”,(0,1)
+QNWCFG: “lte_mimo_layers”
+QNWCFG: “nr5g_mimo_layers”,(0,1)
+QNWCFG: “wcdma_tx_power”
+QNWCFG: “lte_band_priority”,
+QNWCFG: “nr5g_band_priority”,
+QNWCFG: “cause7_map_cause14”,(0,1)
+QNWCFG: “nr5g_ul_256qam”,<enable_fr1>,<enable_fr2>
+QNWCFG: “msearch_bscan_sep”,(0-500)
+QNWCFG: “thin_ui_cfg”,(0,1)
+QNWCFG: “lte_pco”,(0-2)
+QNWCFG: “freq_info”,(0,1)
+QNWCFG: “msisdn”,
+QNWCFG: “lte_fgi_fdd”,<FGI_FDD>
+QNWCFG: “lte_fgi_tdd”,<FGI_TDD>
+QNWCFG: “sysmode”
+QNWCFG: “nr5g_ulbw”,(0,1)
+QNWCFG: “cops_auto_mode”,(0,1)
+QNWCFG: “nitz_ons”
+QNWCFG: “clr_guti”
+QNWCFG: “nr5g_mimo_info”
+QNWCFG: “lte_mimo_info”
+QNWCFG: “3gpp_rel”,<lte_rel>,<nr5g_rel>
+QNWCFG: “nr5g_pathloss”,(0,1)
+QNWCFG: “center_arfcn_info”
+QNWCFG: “rlf_config”,<enable_debug>,<nsa_miscfg_candlist_repeat_count>,<nsa_mi>
+QNWCFG: “fr2sa_enable”,(0,1)
+QNWCFG: “bwp_ueinfo_enable”,(0,1)
+QNWCFG: “nr_rachfailure”,(0,1)
+QNWCFG: “nr5g_cell_info”,(0,1)
+QNWCFG: “hplmn_search_timer”,(0-1530)
+QNWCFG: “eth_cfg”,(0,1)
