EC20移动物联卡怎么拨号上不去呢?
[2026-03-11_00:42:58:627]AT
[2026-03-11_00:42:58:627]OK
[2026-03-11_00:43:02:784]ATI
[2026-03-11_00:43:02:784]Quectel
[2026-03-11_00:43:02:784]EC20F
[2026-03-11_00:43:02:784]Revision: EC20CEFRSGR08A02M2G
[2026-03-11_00:43:02:784]OK
[2026-03-11_00:43:11:328]AT+CFUN=1
[2026-03-11_00:43:11:328]OK
[2026-03-11_00:43:19:610]AT+CPIN?
[2026-03-11_00:43:19:610]+CPIN: READY
[2026-03-11_00:43:19:610]OK
[2026-03-11_00:43:28:939]AT+QCCID
[2026-03-11_00:43:28:939]+QCCID: 898608571924C0722118
[2026-03-11_00:43:28:939]OK
[2026-03-11_00:43:36:535]AT+CNUM
[2026-03-11_00:43:36:535]OK
[2026-03-11_00:43:49:455]AT+QCFG=“disablesrlte”
[2026-03-11_00:43:49:455]+QCFG: “disablesrlte”,0
[2026-03-11_00:43:49:455]OK
[2026-03-11_00:44:02:839]AT+QCFG=“nwscanmode”,0
[2026-03-11_00:44:02:839]ERROR
[2026-03-11_00:44:10:682]AT+QCFG=“nwscanmode”,0
[2026-03-11_00:44:10:682]OK
[2026-03-11_00:44:22:044]AT+QCFG=“nwscanmode”,0
[2026-03-11_00:44:22:044]OK
[2026-03-11_00:44:33:899]AT+QCFG=“nwscanseq”,00
[2026-03-11_00:44:33:915]OK
[2026-03-11_00:45:11:619]AT+QICSGP=1,1,“CMIOTCDJGJ.SC”,“”,“”,2
[2026-03-11_00:45:11:619]OK
[2026-03-11_00:45:21:983]AT+CGREG=2
[2026-03-11_00:45:21:983]OK
[2026-03-11_00:45:27:274]AT+CREG=2
[2026-03-11_00:45:27:274]OK
[2026-03-11_00:45:32:317]AT+CGREG?
[2026-03-11_00:45:32:317]+CGREG: 2,2
[2026-03-11_00:45:32:317]OK
[2026-03-11_00:45:37:752]AT+CREG?
[2026-03-11_00:45:37:752]+CREG: 2,2
[2026-03-11_00:45:37:752]OK
[2026-03-11_00:45:42:614]AT+CGATT?
[2026-03-11_00:45:42:614]+CGATT: 0
[2026-03-11_00:45:42:614]OK
[2026-03-11_00:45:48:265]AT+CSQ
[2026-03-11_00:45:48:265]+CSQ: 20,99
[2026-03-11_00:45:48:265]OK
[2026-03-11_00:46:43:726]AT+CGACT=1,1
[2026-03-11_00:46:43:757]+CME ERROR: 30
卡和模组的IMEI是绑定的,卡在其他设备上也是可以上网的
那换张卡(普通的手机卡) 插上去能用吗?
可以插下
AT+CEER?
AT+QCEER
不一定能看出来。
[2026-03-11_20:11:31:234]AT+CGDCONT=1,“IPv4v6”,“cmnet”
[2026-03-11_20:11:31:250]OK
[2026-03-11_20:11:39:462]AT+CGACT=1,1
[2026-03-11_20:11:39:493]+CME ERROR: 30
我换了一张移动的卡,正规的手机卡
[2026-03-11_20:05:22:056]AT+CCID
[2026-03-11_20:05:22:713]+CCID: 89860097211480489614
[2026-03-11_20:05:22:713]OK
[2026-03-11_20:06:09:781]AT+CPIN?
[2026-03-11_20:06:09:797]+CPIN: READY
[2026-03-11_20:06:09:797]OK
[2026-03-11_20:06:19:434]AT+CEREG?
[2026-03-11_20:06:19:434]+CEREG: 0,2
[2026-03-11_20:06:19:434]OK
AT+CEER?和AT+QCEER这两个命令会报错
[2026-03-11_20:06:52:418]AT+CEER?
[2026-03-11_20:06:52:418]ERROR
[2026-03-11_20:06:58:381]AT+QCEER
[2026-03-11_20:06:58:381]ERROR
能不能给我一份最新的固件,移动的卡,模组是EC20CEFRSGR08A02M2G
查下
AT+CFUN?
AT+QCFG=”band”
这个有没有问题。
[2026-03-13_21:39:42:544]AT+QCFG=“band”
[2026-03-13_21:39:42:544]+QCFG: “band”,0x493,0x1e200000095,0x21
[2026-03-13_21:39:42:544]OK
[2026-03-13_21:39:48:748]AT+CFUN?
[2026-03-13_21:39:48:748]+CFUN: 1
[2026-03-13_21:39:48:748]OK
[2026-03-13_21:57:22:851]AT+CPIN?
[2026-03-13_21:57:22:851]+CPIN: READY
[2026-03-13_21:57:22:851]OK
[2026-03-13_21:57:29:206]AT+CREG?
[2026-03-13_21:57:29:206]+CREG: 0,1
[2026-03-13_21:57:29:206]OK
[2026-03-13_21:57:42:606]AT+CSQ
[2026-03-13_21:57:42:606]+CSQ: 23,99
[2026-03-13_21:57:42:606]OK
[2026-03-13_21:57:48:208]AT+CGDCONT?
[2026-03-13_21:57:48:208]+CGDCONT: 1,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
[2026-03-13_21:57:48:208]+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
[2026-03-13_21:57:48:208]+CGDCONT: 3,“IPV4V6”,“SOS”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
[2026-03-13_21:57:48:208]OK
[2026-03-13_22:00:13:811]
[2026-03-13_22:00:13:811]+QCFG: “usbnet”,0
[2026-03-13_22:00:13:811]OK
刷完固件了,在Windows下可以通过*99#拨号成功但是不能上网
[2026-03-13_21:40:08:422]AT+CEER?
[2026-03-13_21:40:08:422]ERROR
[2026-03-13_21:40:15:696]AT+QCEER
[2026-03-13_21:40:15:696]ERROR
EC20CEFRSGR08A07M2G说是模块固件不支持物联网卡,是不是要升级到5Mxx才行是不
先用自己的手机卡看看能不能注网。
要看PS域没问题才能激活PDP.
AT+CEREG?
AT+QENG="servingcell”
[2026-03-15_18:35:18:619]AT
[2026-03-15_18:35:18:619]OK
[2026-03-15_18:35:23:344]AT+CEREG?
[2026-03-15_18:35:23:344]+CEREG: 0,0
[2026-03-15_18:35:23:344]OK
[2026-03-15_18:35:29:952]AT+QENG="servingcell”
[2026-03-15_18:35:29:952]ERROR
[2026-03-15_18:35:36:405]AT+QENG=“servingcell”
[2026-03-15_18:35:36:405]+QENG: “servingcell”,“LIMSRV”,“LTE”,“FDD”,460,00,74EA408,161,1300,3,5,5,7552,-102,-13,-69,-3,25
[2026-03-15_18:35:36:405]OK
我好像发现了一个问题,27,99就能注册,23,99就注册不了,但是23,99都-83dBm了吧
[2026-03-15_18:46:24:318]+CGDCONT: 1,“IPV4V6”,“cmnet”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
[2026-03-15_18:46:24:318]+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
[2026-03-15_18:46:24:318]+CGDCONT: 3,“IPV4V6”,“SOS”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
[2026-03-15_18:46:24:318]OK
[2026-03-15_18:46:31:583]
[2026-03-15_18:46:31:583]+CGATT: 1
[2026-03-15_18:46:31:583]OK
[2026-03-15_18:46:39:364]
[2026-03-15_18:46:39:364]+CGPADDR: 1,“10.80.250.76,36.9.141.94.4.17.196.25.0.0.0.0.0.0.0.1”
[2026-03-15_18:46:39:364]+CGPADDR: 2,“0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”
[2026-03-15_18:46:39:364]+CGPADDR: 3,“0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”
[2026-03-15_18:46:39:364]OK
好像又正常了,拨号也能正常上网了 就是很卡
现在有一个问题就是插入物联网卡信号就是23,99,插入自己的手机卡就是99,99
这个就是没有注网成功。
是这个LIMSRV字符吗
是的。“LIMSRV” 用户设备正在小区上据守,但尚未在网络上注册。
找到问题了,模组坏了 :grin: ,换了一个就自己就注册完了
