我们是在4490的高通原生基线上调试,配置完cdt后开到uefi会重启,我们想参考下开发板的amss部分代码还在那些地方做了适配,附上相关log,非常感谢支持
S - OEM Config Row 0 @ 0x221c2108 = 0x0000000000000000
S - OEM Config Row 1 @ 0x221c2110 = 0x0000000000000000
S - Feature Config Row 0 @ 0x221c2128 = 0x162dbb001b800000
S - Feature Config Row 1 @ 0x221c2130 = 0x0000000554badb05
S - OEM LCS:PROD
S - Core 0 Frequency, 1478 MHz
S - PBL Patch Ver: 0
S - PBL freq: 600 MHZ
S - -------------------------
PBL Timestamps (in usecs)
APBL start: 340
APBL Boot Media Detect Start: 7440
APBL Boot Media Detect End: 36461
APBL SHELF Load+Auth Start: 36463
APBL ELF MD Load Start: 44546
APBL ELF MD Load End: 44795
APBL ELF Seg Load Start: 44796
APBL ELF Seg Load End: 52216
APBL SEQ Valid Set: 52238
APBL SEQ SA ACK Rcvd: 62908
APBL ELF MD Load Start: 64118
APBL ELF MD Load End: 65025
APBL ELF Auth Start: 65030
APBL ELF Auth End: 74736
APBL ELF Seg Load Start: 74738
APBL ELF Seg Load End: 78291
APBL ELF Seg Verify Start: 78293
APBL ELF Seg Verify End: 83341
APBL ELF MD Load Start: 84473
APBL ELF MD Load End: 85275
APBL ELF Auth Start: 85276
APBL ELF Auth End: 95001
APBL ELF Seg Load Start: 95001
APBL ELF Seg Load End: 102343
APBL ELF Seg Verify Start: 102343
APBL ELF Seg Verify End: 106681
APBL SHELF Load+Auth End: 106786
APBL TME PBL Exit: 106788
APBL XBL_SC Exit Check: 107121
APBL XBL_SC Exit Ack: 115648
APBL Exit: 115651
B - 116479 - SBL1, Start
B - 297283 - SBL1 BUILD @ 07:39:17 on Dec 17 2024
B - 306647 - usb: HS: usb_shared_xbl_dtb_node_init dtb inaccessible , 0x2
B - 312320 - usb: usb_hs_phy_cfg size , 0x20
B - 313631 - usb: eud_ser_upd , 0x6cfa33e6
D - 12413 - sbl1_hw_init
D - 488 - media_init:1
D - 0 - blacklist disable
B - 327448 - OEM_MISC - Image Load, Start
D - 2318 - Auth Metadata
D - 8845 - OEM_MISC - Image Loaded, Delta - (5016 Bytes)
B - 337452 - QTI_MISC - Image Load, Start
D - 8753 - Auth Metadata
D - 16165 - QTI_MISC - Image Loaded, Delta - (4624 Bytes)
B - 354959 - APDP - Image Load, Start
D - 5734 - APDP - Image Loaded, Delta - (0 Bytes)
D - 31 - boot_dload_dump_security_regions
D - 0 - EUD Init
D - 0 - blacklist enable
D - 3081 - DP_Milestone
D - 3813 - Auth Metadata
D - 5429 - sbl1_xblconfig_init
B - 386252 - XBL Config - Image Load, Start
B - 389546 - DTB: looking for default S_DTB_NAME
B - 395127 - DTB: published DEFAULT_BLOB_ID
D - 8997 - boot_pre_ddr_dtb_init
B - 410164 - PMIC A:2.0 B:1.1 E:1.3 I:1.0
B - 411872 - PM: PM8 0x240
B - 414403 - PM: xVdd reset
B - 416996 - PM: Event 0x09, Fault data: 0x00 0x00 0x00
B - 419832 - PM:
[21:18:11.110]收←◆Event 0x0A, Fault data: 0x00 0x00 0x00
B - 425139 - PM: PON by SYSOK
B - 431605 - PM: PBS_RAM 0 reloading
[21:18:11.155]收←◆B - 482266 - PM: PBS_RAM 1 reloading
[21:18:11.282]收←◆B - 608871 - PM: PBS_RAM 2 reloading
[21:18:11.329]收←◆B - 655628 - PM: Verifying PON-Trigger specific configurations & current PON-Trigger
B - 661362 - PM: All PON-Trigger specific configs verified. Proceeding to BOOT
B - 669292 - PM: SET_VAL:Skip
B - 671183 - PM: PSI: b0x20_v0x32
B - 677557 - PM: Device Init # SPMI Transn: 15106
D - 274805 - pm_device_init, Delta
B - 682407 - pm_driver_init, Start
B - 693051 - PM: Driver Init # SPMI Transn: 517
D - 7167 - pm_driver_init, Delta
D - 294935 - sbl1_pmic_init
D - 18818 - media_init:2
[21:18:11.551]收←◆B - 875228 - UFS Spec Version: 2.20
B - 877302 - UFS INQUIRY ID: SAMSUNG KM5P9001DM-B424 0300
B - 880169 - UFS Boot LUN: 1
B - 885567 - UFS Total Size: 64 GB
B - 895937 - UFS Speed: Gear 3 Lane 2 Rate B
D - 180804 - media_init:3
D - 61 - boot_wdog_disable_check
D - 92 - init-logstomedia
D - 0 - shrm_load_cancel
B - 910211 - SHRM - Image Load, Start
D - 4483 - Auth Metadata
D - 10614 - SHRM - Image Loaded, Delta - (51972 Bytes)
D - 244 - boot_cdt_init
B - 926376 - CDT - Image Load, Start
B - 929152 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:3
D - 10949 - sbl1_hw_platform_pre_ddr
B - 940101 - PM: Charging applicable is true
B - 944798 - usb: usb-phy: chgr value
B - 948275 - usb: chgr - SDP_CHARGER
B - 951996 - usb: qusb_dci_eud_init
B - 956541 - PM: Battery ID: 99673Ohm
B - 960506 - PM: Vbat:4070mV
B - 963861 - PM: VBAT: 4070mV IBAT: 0mA
B - 966026 - PM: CHG Init # SPMI Transn: 15708
B - 969961 - vsense_init, Start
D - 0 - vsense_init, Delta
D - 49502 - sbl1_hw_pre_ddr_init
D - 122 - boot_fedl_check
D - 30 - boot_dload_handle_forced_dload_timeout
D - 305 - sbl1_load_ddr_training_data
B - 1000979 - Pre_DDR_clock_init, Start
D - 31 - Pre_DDR_clock_init, Delta
D - 12902 - sbl1_ddr_set_params
B - 1012691 - sbl1_ddr_init, Start
B - 1016138 - LP4 DDR detected
B - 1021079 - DDR_INIT with shrm.elf
B - 1028551 - eCDT MRR - Data Starting Address: 0x19056D00
B - 1029161 - ddr_init = 1 cold boot
D - 18209 - sbl1_ddr_init, Delta
B - 1037793 - DSF version = 272.56.160
B - 1041178 - Manufacturer ID = 0x1, Device Type = 0x7
B - 1044930 - Rank 0 size = 2048 MB, Rank 1 size = 2048 MB
B - 1050115 - Row Hamming DDR
B - 1055635 - LP4 MR_value = 0x8
B - 1058594 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH0 & CS0
B - 1067591 - LP4 MR_value = 0x8
B - 1072593 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH0 & CS1
B - 1081621 - LP4 MR_value = 0x8
B - 1086623 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH1 & CS0
B - 1095651 - LP4 MR_value = 0x8
B - 1100623 - Row Hammer Check : DRAM supports unlimited MAC Value : MR_RH[OP2:0 = 0] & MR_RH[OP3 = 1] for CH1 & CS1
D - 97051 - sbl1_ddr_init
D - 0 - store-logstomedia
B - 1117581 - do_ddr_training, Start
B - 1134051 - DDR: Start of DDR Training Init
[21:18:16.851]收←◆B - 6174054 - TRAINING TIME PER FUNCTION:
B - 6174054 - GROUP,NAME,CALL_COUNT,TOTAL_TIME(us)
B - 6178202 - PLL Pre-Cal,PLL Precal,5,28547
B - 6183082 - DCC,GHS PLL DCC Monitor,2,17568
B - 6187474 - DCC,PLL DCC Monitor,5,12811
B - 6191927 - DCC,CLKIO DCC Monitor,7,29341
B - 6196044 - DCC,RDT4 DCC Monitor,5,22508
B - 6200345 - RCW,RCW CDC/Full Cycle Sweep,1,246196
B - 6204523 - LowSpeed DIT,tWCK2DQI (DIT),1,366
B - 6209525 - R,RD_Matched_1TV,1,39162
B - 6214161 - R,RD_Matched_1UV,1,280112
B - 6218004 - R,RD_Matched_2OV,1,79575
B - 6221939 - R,RD_Matched_3RDQDCC,1,99308
B - 6225782 - R,RD_Matched_4RDQS_PB,1,19764
B - 6229991 - R,RD_Matched_4RDDQS,5,180833
B - 6234291 - R,PHY_SED_RD,2,407175
B - 6238470 - R,READ Scaling,2,183
B - 6242069 - HighSpeed DIT,DIT - Periodic Training,3,1067
B - 6245546 - W,DRAM Vref DQ CDC perbit,1,830759
B - 6251158 - W,DRAM Vref,1,298199
B - 6255885 - W,DRAM Vref DQ DCC,2,970937
B - 6259393 - W,DQ CDC perbit (NO VREF),5,480100
B - 6263510 - W,PHY_SED_LP4_WR_Print,2,875228
B - 6268238 - W,Low Freq DQ CDC perbit,1,113948
B - 6272691 - TRAINING TIME TOTAL(us):
[21:18:16.969]收←◆5033687
B - 6281963 - Current DDR Freq = 1709 MHz
B - 6281993 - Max enabled DDR Freq = 2092 MHz
B - 6286019 - DDR: End of DDR Training Init
B - 6290442 - DDR: serial # 0x6cfa33e6
D - 5180638 - do_ddr_training, Delta
D - 5185366 - xbl_trng_ddi_seq
D - 30 - store-logstomedia
D - 762 - xbl_map_smem
D - 0 - boot_smem_debug_init
D - 824 - boot_smem_init
D - 823 - boot_smem_init
D - 122 - boot_ddr_share_data_to_aop
D - 61 - boot_populate_ddr_details_shared_table
B - 1031205 - MTE is DISABLED
D - 5002 - boot_update_ram_partition_table
B - 1039104 - Pimem init cmd, entry
D - 8143 - Pimem init cmd, exit
B - 1051914 - External heap init, Start
B - 1055025 - External heap init, End
D - 24461 - sbl1_post_ddr_init
D - 0 - sbl1_hw_init_secondary
B - 1066798 - DDR - Image Load, Start
B - 1070367 - Find DTB for chipinfo:[8d024501000000] and platforminfo:[2203010000000000]
B - 1079822 - DTB: looking for default D_DTB_NAME
B - 1084397 - DTB: published DEFAULT_BLOB_ID
D -
[21:18:47.564]收←◆ 16714 - boot_platform_dtb_init
B - 1091442 - usb: UFS Serial - 1a70ffa3
D - 3538 - boot_usb_update_serial
D - 0 - boot_usb_handle_charger
D - 30 - sbl1_hw_platform_smem
D - 0 - ramdump_load_cancel
B - 1109590 - RamDump - Image Load, Start
D - 3324 - RamDump - Image Loaded, Delta - (0 Bytes)
D - 0 - boot_update_abnormal_reset_status
D - 0 - boot_cache_set_memory_barrier
D - 30 - boot_smem_alloc_for_minidump
D - 0 - boot_shrm_mini_dump_init
D - 0 - boot_minidump_register_regions
D - 61 - boot_smem_store_pon_status
B - 1144116 - Pegging-tool : Result is 0 and test_mode is 0
D -
[21:18:47.627]收←◆ 3935 - boot_clock_init_rpm
D - 0 - boot_vsense_copy_to_smem
D - 183 - sbl1_tlmm_init
D - 0 - sbl1_efs_handle_cookies
B - 1174982 - PM: PM Total Mem Allocated: 6826
D - 12139 - sbl1_pm_aop_pre_init_wrapper
B - 1179526 - AOP Config - Image Load, Start
D - 2440 - Auth Metadata
D - 11285 - AOP Config - Image Loaded, Delta - (9048 Bytes)
B - 1196545 - AOP - Image Load, Start
D - 11560 - Auth Metadata
D - 24614 - AOP - Image Loaded, Delta - (228248 Bytes)
D
[21:18:47.703]收←◆- 0 - aop_loaded
D - 0 - boot_prepare_cpucp
B - 1229119 - CPUCPFW - Image Load, Start
D - 4849 - Auth Metadata
D - 29982 - CPUCPFW - Image Loaded, Delta - (99060 Bytes)
D - 0 - boot_reset_cpucp
B - 1264835 - QSEE Dev Config - Image Load, Start
D - 2958 - Auth Metadata
D - 10919 - QSEE Dev Config - Image Loaded, Delta - (39056 Bytes)
B - 1281488 - QSEE - Image Load, Start
D - 5429 - Auth Metadata
[21:18:47.842]收←◆D - 98362 - QSEE - Image Loaded, Delta - (3673377 Bytes)
D - 0 - sbl1_save_qsee_image_info
B - 1386133 - DTB: Vibration Enabled
D - 3873 - sbl1_hw_play_vibr
B - 1392904 - SEC - Image Load, Start
D - 3294 - SEC - Image Loaded, Delta - (0 Bytes)
B - 1399797 - QHEE - Image Load, Start
D - 4911 - Auth Metadata
[21:18:47.890]收←◆D - 28548 - QHEE - Image Loaded, Delta - (1270832 Bytes)
B - 1428376 - APPSBL - Image Load, Start
D - 3202 - Auth Metadata
D - 36020 - APPSBL - Image Loaded, Delta - (2756472 Bytes)
D - 0 - sbl1_save_appsbl_index
B - 1470374 - SBL1, End
D - 1356183 - SBL1, Delta
S - Flash Throughput, 191924 KB/s (8252767 Bytes, 43679 us)
S - DDR Frequency, 1708 MHz
[21:18:48.244]收←◆0 1.783952 Hypervisor cold boot, version: gunyah-fb18f16d
[21:18:48.268]收←◆b prod (Mon Sep 16 15:30:42 2024 UTC)
[RM]Starting Resource Manager, version: 799d0e92 (Sun Sep 15 22:37:21 2024 UTC)
[RM]init completed, disabling UART
0 1.841883 Hypervisor UART is disabled!
UEFI Start [ 1847]
- 0x0A7001000 [ 1849] Sec.efi
ASLR : ON
DEP
[21:18:48.383]收←◆ : ON (RTB)
Timer Delta : +1 mS
RAM Installed : 4093 MB (0x00FFD00000)
RAM Entry 0 : Base 0x0080000000 Size 0x0068E00000
RAM Entry 1 : Base 0x00E9500000 Size 0x0000000000
RAM Entry 2 : Base 0x00EA700000 Size 0x0015900000
RAM Entry 3 : Base 0x0800000000 Size 0x003FE00000
RAM Entry 4 : Base 0x0840000000 Size 0x003C400000
RAM Available : 4009 MB (0x00FA900000)
Minidump : ON
Init 1 aux cores of 7
Init CPU core 1
Continue booting UEFI on Core 0
Scheduler up on Core 1
UEFI Ver : 6.0.260213.BOOT.MXF.2.0-01088-WAIPIO-1
Build Info : 64b Feb 13 2026 18:05:49
Boot Device : UFS
PROD Mode : TRUE
Retail : TRUE
PM: Battery ID: 99712Ohm
PM: Vbat:4354mV
PM: VBAT: 4355mV IBAT: 0mA
PM: *** Failed to detect external I2C PMIC. PMIC is left at default state. (i2c status : 22) ***
ERROR: C90000002:V03000007 I0 5776232E-082D-4B75-9A0E-FE1D13F7A5D9
ASSERT DebugLib.c +78: Format != ((void *) 0)
