移动5G专网注册失败 RM520-CN
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.261033] [modem0] processing user request to disconnect modem: all bearers
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.261139] [modem0] all requested bearers disconnected
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.325604] [modem0] processing user request to connect modem…
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.325664] [modem0] apn: CMIOT5GXTAHLGTELG.HN
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.325684] [modem0] ip type: ipv4
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.325700] [modem0] allowed auth: unknown
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.325728] [modem0] simple connect started…
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.325747] [modem0] simple connect state (4/10): wait to get fully enabled
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.325821] [modem0] simple connect state (5/10): wait after enabled
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.425972] [modem0] simple connect state (6/10): register
Jun 26 23:26:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951564.469939] [modem0] launching automatic network registration…
Jun 26 23:26:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951565.558400] [modem0] 3GPP registration check timed out
Jun 26 23:26:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951565.558448] [modem0] 3GPP registration state changed (searching → idle)
Jun 26 23:26:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951565.558467] [modem0] consolidated registration state: cs ‘idle’, ps ‘idle’, eps ‘idle’, 5gs ‘idle’ → ‘idle’
Jun 26 23:26:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951565.558542] [modem0] state changed (searching → enabled)
Jun 26 23:26:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951565.558776] [modem0] registration in network failed: Network timeout
Jun 26 23:26:07 DHSR-2XC2P4M12 ModemManager[12904]: [1750951567.510068] [modem0] 3GPP registration state changed (idle → searching)
Jun 26 23:26:07 DHSR-2XC2P4M12 ModemManager[12904]: [1750951567.510131] [modem0] consolidated registration state: cs ‘searching’, ps ‘searching’, eps ‘emergency-only’, 5gs ‘searching’ → ‘searching’
Jun 26 23:26:07 DHSR-2XC2P4M12 ModemManager[12904]: [1750951567.510253] [modem0] state changed (enabled → searching)
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.320924] [modem0] processing user request to disconnect modem: all bearers
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.321030] [modem0] all requested bearers disconnected
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.385952] [modem0] processing user request to connect modem…
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.386008] [modem0] apn: CMIOT5GXTAHLGTELG.HN
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.386028] [modem0] ip type: ipv4
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.386045] [modem0] allowed auth: unknown
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.386073] [modem0] simple connect started…
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.386092] [modem0] simple connect state (4/10): wait to get fully enabled
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.386170] [modem0] simple connect state (5/10): wait after enabled
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.486323] [modem0] simple connect state (6/10): register
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.532490] [modem0] launching automatic network registration…
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.660600] [modem0] 3GPP registration check timed out
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.660636] [modem0] 3GPP registration state changed (searching → idle)
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.660656] [modem0] consolidated registration state: cs ‘idle’, ps ‘idle’, eps ‘idle’, 5gs ‘idle’ → ‘idle’
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.660733] [modem0] state changed (searching → enabled)
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.660950] [modem0] registration in network failed: Network timeout
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.724790] [modem0] 3GPP registration state changed (idle → searching)
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.724843] [modem0] consolidated registration state: cs ‘searching’, ps ‘searching’, eps ‘emergency-only’, 5gs ‘searching’ → ‘searching’
Jun 26 23:27:04 DHSR-2XC2P4M12 ModemManager[12904]: [1750951624.724956] [modem0] state changed (enabled → searching)
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.438815] [modem0] processing user request to disconnect modem: all bearers
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.438919] [modem0] all requested bearers disconnected
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.503466] [modem0] processing user request to connect modem…
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.503517] [modem0] apn: CMIOT5GXTAHLGTELG.HN
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.503537] [modem0] ip type: ipv4
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.503553] [modem0] allowed auth: unknown
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.503591] [modem0] simple connect started…
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.503609] [modem0] simple connect state (4/10): wait to get fully enabled
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.503682] [modem0] simple connect state (5/10): wait after enabled
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.603829] [modem0] simple connect state (6/10): register
Jun 26 23:28:03 DHSR-2XC2P4M12 ModemManager[12904]: [1750951683.666683] [modem0] launching automatic network registration…
Jun 26 23:28:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951685.554629] [modem0] 3GPP registration check timed out
Jun 26 23:28:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951685.554676] [modem0] 3GPP registration state changed (searching → idle)
Jun 26 23:28:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951685.554698] [modem0] consolidated registration state: cs ‘idle’, ps ‘idle’, eps ‘idle’, 5gs ‘idle’ → ‘idle’
Jun 26 23:28:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951685.554772] [modem0] state changed (searching → enabled)
Jun 26 23:28:05 DHSR-2XC2P4M12 ModemManager[12904]: [1750951685.554987] [modem0] registration in network failed: Network timeout
Jun 26 23:28:07 DHSR-2XC2P4M12 ModemManager[12904]: [1750951687.538972] [modem0] 3GPP registration state changed (idle → searching)
Jun 26 23:28:07 DHSR-2XC2P4M12 ModemManager[12904]: [1750951687.539030] [modem0] consolidated registration state: cs ‘searching’, ps ‘searching’, eps ‘emergency-only’, 5gs ‘searching’ → ‘searching’
Jun 26 23:28:07 DHSR-2XC2P4M12 ModemManager[12904]: [1750951687.539155] [modem0] state changed (enabled → searching)
Hi @pcboygo
注意到您说是专网卡,请确认apn是否正确配置,另外检查天线是否正常连接。
