使用高通的gstreamer qtiqmmfsrc和qt实现照相机应用
1. 高通提供了qtiqmmfsrc的模块来获取摄像头数据
2. qt中执行下列代码打开摄像头
GstElement \*pipeline = gst_parse_launch("qtiqmmfsrc camera=0 ! video/x-raw(memory:GBM),format=NV12,width=1920,height=1080,framerate=30/1 ! videoconvert ! appsink drop=1 name=appsink", nullptr);
GstElement \*appsink = gst_bin_get_by_name(GST_BIN(pipeline), "appsink");
3. 将图像显示到预览QLabel控件的逻辑
GstSample *sample = gst_app_sink_pull_sample(GST_APP_SINK(appsink));
if (sample) {
    GstBuffer *buffer = gst_sample_get_buffer(sample);
    GstMapInfo map;
    if (gst_buffer_map(buffer, &map, GST_MAP_READ)) {
        if (width == 0) {
            GstCaps *caps = gst_sample_get_caps(sample);
            if (caps) {
                GstStructure *structure = gst_caps_get_structure(caps, 0);
                if (structure) {
                    gst_structure_get_int(structure, "width", &width);
                    gst_structure_get_int(structure, "height", &height);
                gst_caps_unref(caps);
        int y_size = width * height;
        int crop_height = height - 20;
        int crop_y_size = width * crop_height;
        uint8_t *rgb_data = new uint8_t[width * crop_height * 3];
        SwsContext *sws_ctx = sws_getContext(width, crop_height, AV_PIX_FMT_NV12, width, crop_height, AV_PIX_FMT_RGB24, SWS_BILINEAR, NULL, NULL, NULL);
        int srcStride[2] = {width, width};
        int dstStride[1] = {width * 3};
        uint8_t *srcSlice[2] = {map.data + (20 * width), map.data + y_size + (20 * width / 2)};
        sws_scale(sws_ctx, srcSlice, srcStride, 0, crop_height, &rgb_data, dstStride);
        QImage image(rgb_data, width, crop_height, width * 3, QImage::Format_RGB888);
        int new_width = 800;
        int new_height = static_cast<int>(static_cast<double>(crop_height) * (new_width / static_cast<double>(width)));
        QImage scaledImage = image.scaled(new_width, new_height, Qt::KeepAspectRatio, Qt::SmoothTransformation);
        previewLabel->setPixmap(QPixmap::fromImage(scaledImage));
        delete[] rgb_data;
        sws_freeContext(sws_ctx);
        gst_buffer_unmap(buffer, &map);
    gst_sample_unref(sample);
4. 拍照保存jpg图片的逻辑
if (sample) {
    GstMapInfo map;
        if (width == 0) {
            if (caps) {
                if (structure) {
        QImage scaledImage = image.scaled(width, height, Qt::IgnoreAspectRatio, Qt::SmoothTransformation);
        QString fileName = QString("IMG_%1.jpg").arg(QDateTime::currentDateTime().toString("yyyyMMdd_HHmmss"));
        scaledImage.save(fileName);
        delete[] rgb_data;
