radio日志如下:
Quectel RIL Version: Quectel_Android_RIL_Driver_V3.7.0
find quectel module /sys/bus/usb/devices/3-1 idVendor=2c7c idProduct=6002
12-09 17:20:25.725 496 525 D RILU : find_usb_device is 1
12-09 17:20:26.716 496 524 D RILC : dlopen /vendor/lib64/hw/radio.quectel.module.so failed: dlopen failed: library “/vendor/lib64/hw/radio.quectel.module.so” not found
12-09 17:20:26.716 496 524 D RILC : start the service through api…
12-09 17:20:26.716 496 524 D RILC : ql_radio_config_init start
12-09 17:20:26.716 496 524 E RadioConfigFactory: ‘/vendor/manifest.xml’ not exist.
12-09 17:20:26.717 496 524 D RadioConfigFactory: __getIRadioConfigVersion:114 IRadioconfigVersion:2
12-09 17:20:26.717 496 524 D RadioConfigImpl: RadioConfigImpl()
12-09 17:20:26.717 496 524 D RadioConfigImpl_1_2: RadioConfigImpl_1_2:registerAsService(default)
12-09 17:20:26.718 496 524 D RadioConfigFactory: radio_config_register_service status=-2147483648
12-09 17:20:26.718 496 524 D RILC : ql_radio_config_init finish
12-09 17:20:26.718 496 524 D RILC : ql_radio_sap_init start
12-09 17:20:26.718 496 524 D RIL_SAP_1_2: ql_radio_sap_init() start.
12-09 17:20:26.718 496 524 D RIL_SAP_1_2: radio_sap_register_service status=-2147483648
12-09 17:20:26.718 496 524 D RILC : ql_radio_sap_init finish
12-09 17:20:26.726 496 525 D RILU : find /sys/bus/usb/devices/3-1:1.3/ttyUSB1
12-09 17:20:26.726 496 525 D RILU : ttyAT = ttyUSB1
12-09 17:20:26.726 496 525 D RILU : find /sys/bus/usb/devices/3-1:1.2/ttyUSB0
12-09 17:20:26.726 496 525 D RILU : ttyDM = ttyUSB0
12-09 17:20:26.726 496 525 D RILU : find /sys/bus/usb/devices/3-1:1.6/ttyUSB3
12-09 17:20:26.726 496 525 D RILU : ttyGPS = ttyUSB3
12-09 17:20:26.727 496 525 D RILU : MTK debug ql_find_ecm_rndis_ncm: usbnet adapter dir:/sys/bus/usb/devices/3-1:1.0
12-09 17:20:26.727 496 525 D RILU : find /sys/bus/usb/devices/3-1:1.0/net/usb0
12-09 17:20:26.727 496 525 D RILU : usbnet_adapter = usb0
12-09 17:20:26.727 496 525 D RILU : netcard driver: cdc_ether, driver version: 5.10.107
12-09 17:20:26.727 496 525 D RILU : ECM = usb0
12-09 17:20:26.727 496 525 D RILU : kernel_version: 5.10.107
12-09 17:20:26.727 496 525 D RILC : quectel at port is /dev/ttyUSB1
12-09 17:20:26.727 496 525 D RILU : ql_set_autosuspend, enter…
12-09 17:20:26.727 496 525 D RILU : ro_hardware:rk30board
gps_ql日志如下:
open_gps[22]–enter!
12-09 17:20:24.442 D/gps_ql ( 414): gps__get_gps_interface[15]–enter!
12-09 17:20:24.446 D/gps_ql ( 414): [rild-nmea] [0]
12-09 17:20:24.446 D/gps_ql ( 414): get android version:33
12-09 17:20:37.078 D/gps_ql ( 414): ql_gps_get_extension(name=gps-xtra)
12-09 17:20:37.079 D/gps_ql ( 414): ql_gps_get_extension(name=agps_ril)
12-09 17:20:37.080 D/gps_ql ( 414): ql_gps_get_extension(name=agps)
12-09 17:20:37.081 D/gps_ql ( 414): ql_gps_get_extension(name=gps_navigation_message)
12-09 17:20:37.081 D/gps_ql ( 414): ql_gps_get_extension(name=gps_measurement)
12-09 17:20:37.082 D/gps_ql ( 414): ql_gps_get_extension(name=gps-debug)
12-09 17:20:37.083 D/gps_ql ( 414): ql_gps_get_extension(name=gnss_configuration)
12-09 17:20:37.083 D/gps_ql ( 414): ql_gps_get_extension(name=gps_geofencing)
12-09 17:20:37.085 D/gps_ql ( 414): GPS DRIVER VERSION: Quectel_Android_GPS_Driver_V2.2.22
12-09 17:20:37.085 D/gps_ql ( 414): MODULE_TYPE:
12-09 17:20:37.085 D/gps_ql ( 414): QL_GPS_CHANNEL:rild-nmea
12-09 17:20:37.085 D/gps_ql ( 414): BAUD_RATE:0
12-09 17:20:37.087 D/gps_ql ( 414): init_times = 0, s->init = 0
12-09 17:20:37.087 D/gps_ql ( 414): ql_gps_state_init[539]–enter!
12-09 17:20:37.087 D/gps_ql ( 414): ql_gps_state_init start
12-09 17:20:37.087 D/gps_ql ( 414): Android gps will read from ‘rild-nmea’ channel
12-09 17:20:37.088 D/gps_ql ( 414): gps state initialized
12-09 17:20:37.088 D/gps_ql ( 414): set gps status to GPS_STATUS_ENGINE_ON
12-09 17:20:37.088 D/gps_ql ( 414): ql_gps_xtra_init(callbacks=0x70268302f0)
12-09 17:20:37.088 D/gps_ql ( 414): ql_gps_Xtra_start: gpsXtraCallbacks=0x70268302f0
12-09 17:20:37.090 D/gps_ql ( 414): ql_loc_agps_ril_init[37]–enter!
12-09 17:20:37.090 D/gps_ql ( 414): ql_loc_agps_ril_init[38]–leave!
12-09 17:20:37.092 D/gps_ql ( 414): ql_gps_cleanup()
12-09 17:20:37.092 D/gps_ql ( 414): report_gps_state enter
12-09 17:20:37.092 D/gps_ql ( 414): reportStatus GPS_STATUS_SESSION_END
12-09 17:20:37.092 D/gps_ql ( 414): report_gps_state leave
12-09 17:20:37.092 D/gps_ql ( 414): reportStatus to GPS_STATUS_ENGINE_OFF
12-09 17:20:37.092 D/gps_ql ( 414): ql_gps_state_done[233]–enter!
12-09 17:20:37.092 D/gps_ql ( 414): ql_gps_state_stop[247]–enter!
12-09 17:20:37.093 D/gps_ql ( 414): deal_cmd[206]–enter and cmd is 2!
12-09 17:20:37.093 D/gps_ql ( 414): ql_send_to_target() start
12-09 17:20:37.093 D/gps_ql ( 414): ql_send_to_target() end
12-09 17:20:37.093 D/gps_ql ( 414): deal_cmd[228]–exit!
12-09 17:20:37.093 D/gps_ql ( 414): report_gps_state enter
12-09 17:20:37.093 D/gps_ql ( 414): reportStatus GPS_STATUS_SESSION_END
12-09 17:20:37.093 D/gps_ql ( 414): report_gps_state leave
12-09 17:20:37.093 D/gps_ql ( 414): reportStatus to GPS_STATUS_ENGINE_OFF
12-09 17:20:37.097 D/gps_ql ( 414): Error connecting rild-nmea (Connection refused)
12-09 17:20:37.098 D/gps_ql ( 414): fail to open GPS channel !
12-09 17:20:37.102 D/gps_ql ( 414): gps_state_thread[260]–enter!
12-09 17:20:37.103 D/gps_ql ( 414): gps thread running
12-09 17:20:37.112 D/gps_ql ( 414): GPS DRIVER VERSION: Quectel_Android_GPS_Driver_V2.2.22
12-09 17:20:37.112 D/gps_ql ( 414): MODULE_TYPE:
12-09 17:20:37.112 D/gps_ql ( 414): QL_GPS_CHANNEL:rild-nmea
12-09 17:20:37.112 D/gps_ql ( 414): BAUD_RATE:0
12-09 17:20:37.113 D/gps_ql ( 414): init_times = 1, s->init = 1
12-09 17:20:37.113 D/gps_ql ( 414): set gps status to GPS_STATUS_ENGINE_ON
12-09 17:20:37.113 D/gps_ql ( 414): ql_gps_xtra_init(callbacks=0x70268302f0)
12-09 17:20:37.114 D/gps_ql ( 414): ql_loc_agps_ril_init[37]–enter!
12-09 17:20:37.114 D/gps_ql ( 414): ql_loc_agps_ril_init[38]–leave!
12-09 17:20:38.098 D/gps_ql ( 414): Error connecting rild-nmea (Connection refused)
12-09 17:20:38.098 D/gps_ql ( 414): fail to open GPS channel !
12-09 17:20:39.099 D/gps_ql ( 414): Error connecting rild-nmea (Connection refused)
