这是他的启动日志
[INFO: PlatInfo ] CHIP_ID: 0x1602, REV_ID: 0xA0, AROM_VER: 2022.11.06
[INFO: PlatInfo ] PLATFORM: CRANELR (SILICON)
[INFO: Main ]
[INFO: Main ] Starting AROM-CRANE (Version: 2022.11.11)
[INFO: ClkDrv ] QSPI clock configured at 13 MHz, level 1
[INFO: QspiFlash ] Detecting QSPI flash devices…
[INFO: QspiFlash ] Found a known spi flash device “XM25LU32C”
[INFO: QspiFlash ] SPI nor flash: Manufacturer ID: 0x20, Device ID: 0x5016
[INFO: BootCtrl ] Loading bootloader from QSPI flash…
[INFO: UbiSimple ] Detected peb size is 4096, the first good peb number is 0
[INFO: Crypto ] Initializing crypto library…
[INFO: Main ] Running in normal booting mode.
[INFO: Main ] Loading…
[INFO: Bl1Main ] Welcome to boot rom.
[INFO: Bl1Main ] ### Non-trusted boot mode. ###
[INFO: Bl1Main ] Found preboot volume, size is 26300 bytes
[INFO: Bl1Main ] BL1: Trying to load and verify BL2 image from volume preboot…
[INFO: BlCommon ] Loading image from #0x99cc to #0x80 with size 44296 successfully.
[INFO: Bl1Main ] BL1: OKay.
[INFO: Freq ] Freq change done: CR5 624MHz → 624MHz, AXI 156MHz → 208MHz
[PRI : Preboot ] Executing preboot application…
[PRI : Preboot ] Preboot version: 2023.07.28
[PRI : Preboot ] PMIC REG:0x01,0x10,0xe5,0xe6,0xe2,0xeb
[PRI : Preboot ] PMIC VAL:0x02,0x02,0x02,0x00,0xf2,0x3a
[PRI : Preboot ] cold power on
[PRI : Preboot ] long press, do poweron!!
[PRI : PMIC ] Found PMIC with Id: 0x59
[PRI : PMIC ] [BP_0xe5] = 0x2
[PRI : PMIC ] [BP_0xe6] = 0x0
[PRI : Preboot ] Power_up_reason=0x2.
[WARN: Preboot ] Warning: power_up_reason=0x2 is abnormal.
[PRI : Psram ] [PSRAM] psram init Crane common.
[PRI : EFuse ] No embedded flash
[PRI : Psram ] [PSRAM] psram without phy, start auto detect.
[PRI : Psram ] WB_4M
[INFO: Bl1Main ] Found bootloader volume, size is 36252 bytes
[INFO: Bl1Main ] BL1: Trying to load and verify BL2 image from volume bootloader…
[INFO: BlCommon ] Loading image from #0x7e0f738c to #0x80 with size 14148 successfully.
[INFO: PMIC ] Get restart cmd = 0x0
[PRI : Boot2 ] Executing boot2 application…
[PRI : Boot2 ] Boot2 version: 2023.06.17
[INFO: Loader ] Loading partition table into #0xb0020000
[INFO: Loader ] Done.
[INFO: Loader ] volume “boardid” not found, use empty as default!
[INFO: Boot2 ] BOARD_ID:
[INFO: Boot2 ] Running in try downloading mode.
[PRI : Boot2 ] Waiting for 1000 ms to detect download command.
[INFO: UsbArch ] usb phy reg: 0xd42070a4 = 0x189b
[INFO: PMIC ] Set restart status = 0x0
[INFO: Boot2 ] No download command detected, continue booting.
[INFO: Loader ] Load and verify boot33 from bootloader volume.
[INFO: Loader ] Verify boot33 at #0x7e000000 with size 36252.
[INFO: BlCommon ] Loading image from #0x7e0026a8 to #0x7e100000 with size 34758 successfully.
[INFO: Loader ] Set property: bl2.qspiflash.type = QSPI_NOR
[INFO: Loader ] Booting boot33…
[INFO: Loader ] Boot to 0x7e000000, cpsr should be 0x1d3
[BOOT33]VB_VERSION_DATE :[20230413]
not get erase_rd partition
[DSP] WARNING: decompressed length [0x0003e000] unmatch with expected [0x00052000].
** PC : 0x8001b000
Version: SDK_1.010.103 Feb 29 2024 20:48:47
Ac 4, Board 2, DKB 1
Cinit 2
Flash type: nvm 0, factory 0, fota 0
0 silentreset, don’t need to dump
Phase1Inits
diag Phase1 Init
PSRAM fuse: 13
Bootup not silent
0 [MPU][RGN][ BASE][ END][ SIZE][ PERMISSION][CACHE][SHARE][N_EXE]
0 [MPU][ 0][0x00000000][0xffffffff][0xffffffff][ NO_ACCESS][ 0][ 1][ 1]
0 [MPU][ 1][0x00000000][0x0000ffff][0x0000ffff][ READ_ONLY][ 0][ 0][ 0]
0 [MPU][ 2][0xb0020000][0xb002ffff][0x0000ffff][ FULL_ACCESS][ 0][ 0][ 1]
0 [MPU][ 3][0x80000000][0x81ffffff][0x01ffffff][ FULL_ACCESS][ 0][ 0][ 0]
0 [MPU][ 4][0x7e000000][0x7e3fffff][0x003fffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 5][0x7e368000][0x7e36ffff][0x00007fff][ FULL_ACCESS][ 0][ 1][ 0]
0 [MPU][ 6][0x7e370000][0x7e37ffff][0x0000ffff][ FULL_ACCESS][ 0][ 1][ 0]
0 [MPU][ 7][0x7e380000][0x7e3fffff][0x0007ffff][ FULL_ACCESS][ 0][ 1][ 0]
0 [MPU][ 8][0xc0000000][0xffffffff][0x3fffffff][ FULL_ACCESS][ 0][ 0][ 1]
0 [MPU][ 9][0xd1000000][0xd100ffff][0x0000ffff][ FULL_ACCESS][ 0][ 1][ 1]
0 [MPU][ 10][0x80000000][0x801fffff][0x001fffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 11][0x80200000][0x802fffff][0x000fffff][ FULL_ACCESS][ 1][ 0][ 0]
0 [MPU][ 12][0x00000000][0x00000001][0x00000001][ NO_ACCESS][ 1][ 0][ 0]
0 [MPU][ 13][0x00000000][0x00000001][0x00000001][ NO_ACCESS][ 1][ 0][ 0]
0 [MPU][ 14][0x00000000][0x00000001][0x00000001][ NO_ACCESS][ 1][ 0][ 0]
0 [MPU][ 15][0x80000000][0x80000001][0x00000001][ NO_ACCESS][ 1][ 0][ 1]
0 qspi_nor_find_fbp:find type is 25, protect area=0x0~0x2fffff
1 qspi_nor_set_fbp:org status1[0x0],status2[0x2].
2 qspi_nor_set_fbp:new status1[0x14],status2[0x42].
3 qspi_nor_set_fbp:read back,n_status1[0x14],n_status2[0x42].
11ee8 usbinfo trace to uart debugfail
1217a quectel_nv_fat_read fail, default type=1
1225e quec usb nema cfg nv init: value 0 read failed
20 Usb mode 0, descriptor 69
21 USIMPhase2Init 0
22 power_up_reason: 0x2, power_down_reason: 0x2
1269f read g_quec_nat_flag=0 fail
126a6 mifi mode
24 lwip: lwip_init_all done!
26 ######## quec_system_init ok ########
26 EG800KCNGCR07A04M04 V02
26 Application Start…
27 ATCmdSvrRdy
1312c usb get ifc value fail rts_control=0,cts_control=0
131d1 read remoteip=0,ret=5
131d2 remoteip read fail
132c9 cts value=0 not need init
133a6 debounce timer read fail,use default value
133d7 pin_usage=4 is invalid
38 quec_sim_hot_plug_init
13595 usim wakeup flag read fail,use default value=0
3b usim_1_detect_init
55 quec_modem_channel_init: done
56 modem_msgq_init: done
56 modem_if_init: done
57 modem_router_create: done
57 modem_init_internal: done
58 AT command server ready!
59 Booting done
5b CLAT USE DEFAULT
65 quec_transmission_rate_config!!!
6b SW restart reason: Normal power on
