Current firmware: LG580P03AANR01A04S_SH, 2025/06/06
I need the latest LG580P03 firmware with PPP-B2b support.
$PQTMCFGPPP,W,1,2,120,0.10,0.1568 currently returns $PQTMCFGPPP,ERROR,361.
Please send me the latest firmware supporting PQTMCFGPPP and PQTMPPPNAV, together with the firmware upgrade tool/document.
Re: LG580P03 firmware with PPP-B2b support
- $PQTMCFGPPP / PQTMPPPNAV are supported only on firmware builds that enable the BDS-3 PPP-B2b function. Please confirm the command syntax and parameter ranges against the official Quectel LG580P Protocol Specification before upgrading; a returned error on the current build usually means the running firmware does not yet support the command set.
- Firmware, upgrade tool and upgrade documentation are released by Quectel FAE. Please provide your email address so the corresponding firmware package and tools can be sent to you.
- Please also confirm the exact hardware variant/order code of your LG580P03 module, so the correct firmware package is matched.
本回答仅供参考。若问题已解决,可标记为
