EG800Z-CN_SSL透明模式_16帧后空窗1秒_无CTS阻塞
[00:00:11.210][EG800Z_DIAG] Power ready after 11020 ms
[00:00:11.210][EG800Z_DIAG] UART baud requested=921600, actual=888888
[00:00:11.210][EG800Z_DIAG] Startup RX: bytes=61, boot.rom=0
[00:00:11.220][EG800Z_DIAG] AT OK at 921600 baud
[00:00:11.230][EG800Z] HW flow control ON: RTS=PC1, CTS=PC2
[00:00:11.240][EG800Z_DIAG] AT+IPR?
+IPR: 921600
[00:00:11.250][EG800Z_DIAG] AT+IFC?
+IFC: 2,2
[00:00:11.250][EC800_UPLOAD] Init HTTP upload module
[00:00:11.260]EC800 AT ready, retry=1
[00:00:11.260][EC800_UPLOAD] Checking network…
[2026-09-03 09:18:59.721]# RECV ASCII/140 <<<
[00:00:11.290][EC800_UPLOAD] Network OK, CSQ=24
[00:00:11.320][EC800_UPLOAD] RTC synced 2026-04-08 09:00:10 → 2026-09-03 01:18:56 tzq=32
[2026-09-03 09:19:00.095]# RECV ASCII/52 <<<
[00:00:11.690][EC800_UPLOAD] QIACT context 2 ready
[2026-09-03 09:19:00.142]# RECV ASCII/360 <<<
[00:00:11.730][EC800_UPLOAD] SSL context config OK
[00:00:11.730][EC800_UPLOAD] HTTP upload module init OK
[00:00:11.750]AT+QSCLK=1 configured; PC0/DTR controls sleep
[00:00:11.750]sleep scheduled: upload init finished delay=2000 ms timer=203
[00:00:11.751][UPLOAD_TEST] Network/RTC ready
[00:00:11.751][UPLOAD_TEST] Worker ready, waiting for recordings
[2026-09-03 09:19:21.025]# RECV ASCII/68 <<<
[00:00:32.630]EC800 UART switched: requested=460800, actual=461538
[2026-09-03 09:19:21.089]# RECV ASCII/200 <<<
[00:00:32.690][RT_BAUD] requested=460800 actual=461538 error_ppm=1602 limit_ppm=20000
[00:00:32.690][RT_BAUD] enter requested=460800 ret=0 unsafe=0
[00:00:32.690][EC800_UPLOAD] Checking network…
[2026-09-03 09:19:21.136]# RECV ASCII/170 <<<
[00:00:32.720][EC800_UPLOAD] Network OK, CSQ=24
[00:00:32.730][EC800_UPLOAD] PDP not active, trying to activate…
[00:00:32.741]wavhead_init ch 1, sr 16000, bitw 0
[2026-09-03 09:19:21.643]# RECV ASCII/211 <<<
[00:00:33.220][EC800_UPLOAD] PDP activate OK
[00:00:33.240][RT_MODEM_CFG] transpktsize current ret=37 response=+QICFG: “transpktsize”,1024 OK
[00:00:33.240][RT_MODEM_CFG] transpktsize=1024 already verified
[2026-09-03 09:19:21.707]# RECV ASCII/94 <<<
[00:00:33.300][RT_TRANSPARENT] open :8288 id=1 access_mode=2 transpktsize=1024
[2026-09-03 09:19:24.947]# RECV ASCII/466 <<<
[00:00:36.539][clock-manager]cpu0: 2% cpu1: 18% jlstream: 17% curr_clk:192000000 min_clk:128000000 dest_clk:128000000, 1
[00:00:36.541][CLOCK]—HSB CLK : 128000000
[00:00:36.541][CLOCK]—LSB CLK : 64000000
[00:00:36.541][CLOCK]—XIP CLK : 64000000
[00:0036.542][CLOCK]—PLL_DIV : 1 * 1
[00:00:36.542][CLOCK]—SYS DVDD : 0 / 10 10
[00:00:36.542][CLOCK]—RAM DVDD : 10 / 10
[00:00:36.542][CLOCK]—VDC13 : 10 / 10
[00:00:36.543][CLOCK]—RANGE : 2
[2026-09-03 09:19:25.328]# RECV ASCII/64 <<<
[00:00:36.929]rec.time=4
[00:00:36.929]rec-left.time=235800
[2026-09-03 09:19:26.732]# RECV ASCII/162 <<<
[00:00:38.341][RT_AT_GUARD] ENABLE reason=CONNECT ret=0 link_owner=realtime data_owner=realtime
[00:00:38.341][RT_TRANSPARENT] CONNECT; UART is raw SSL data only
[2026-09-03 09:19:27.344]# RECV ASCII/141 <<<
[00:00:38.940][RT_MONITOR] WebSocket upgrade OK
[00:00:38.943][RT_MONITOR] START sn= file=20260903011917.wav wav_header=0
[2026-09-03 09:19:28.012]# RECV ASCII/111 <<<
[00:00:39.608][RT_CTS_PROBE] begin frame=16 pcm=20480B stream=665ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:28.935]# RECV ASCII/123 <<<
[00:00:40.539][clock-manager]cpu0: 3% cpu1: 26% jlstream: 25% curr_clk:128000000 min_clk:128000000 dest_clk:128000000, 1
[2026-09-03 09:19:29.012]# RECV ASCII/101 <<<
[00:00:40.610][RT_CTS_PROBE] end frame=16 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:29.665]# RECV ASCII/111 <<<
[00:00:41.269][RT_CTS_PROBE] begin frame=32 pcm=40960B stream=2326ms buffered=512B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:29.727]# RECV ASCII/62 <<<
[00:00:41.330]rec.time=8
[00:00:41.330]rec-left.time=235796
[2026-09-03 09:19:30.661]# RECV ASCII/101 <<<
[00:00:42.270][RT_CTS_PROBE] end frame=32 waited=1001ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:31.346]# RECV ASCII/112 <<<
[00:00:42.939][RT_CTS_PROBE] begin frame=48 pcm=61440B stream=3996ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:32.344]# RECV ASCII/101 <<<
[00:00:43.940][RT_CTS_PROBE] end frame=48 waited=1001ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:32.935]# RECV ASCII/123 <<<
[00:00:44.539][clock-manager]cpu0: 3% cpu1: 26% jlstream: 25% curr_clk:128000000 min_clk:128000000 dest_clk:128000000, 1
[2026-09-03 09:19:32.998]# RECV ASCII/112 <<<
[00:00:44.598][RT_CTS_PROBE] begin frame=64 pcm=81920B stream=5655ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:34.000]# RECV ASCII/101 <<<
[00:00:45.600][RT_CTS_PROBE] end frame=64 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:34.125]# RECV ASCII/63 <<<
[00:00:45.729]rec.time=13
[00:00:45.729]rec-left.time=235791
[2026-09-03 09:19:34.657]# RECV ASCII/112 <<<
[00:00:46.259][RT_CTS_PROBE] begin frame=80 pcm=102400B stream=7316ms buffered=512B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:35.656]# RECV ASCII/101 <<<
[00:00:47.260][RT_CTS_PROBE] end frame=80 waited=1001ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:36.328]# RECV ASCII/113 <<<
[00:00:47.928][RT_CTS_PROBE] begin frame=96 pcm=122880B stream=8985ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:36.932]# RECV ASCII/123 <<<
[00:00:48.539][clock-manager]cpu0: 3% cpu1: 26% jlstream: 25% curr_clk:128000000 min_clk:128000000 dest_clk:128000000, 1
[2026-09-03 09:19:37.323]# RECV ASCII/101 <<<
[00:00:48.930][RT_CTS_PROBE] end frame=96 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:37.980]# RECV ASCII/114 <<<
[00:00:49.589][RT_CTS_PROBE] begin frame=112 pcm=143360B stream=10646ms buffered=512B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:38.527]# RECV ASCII/63 <<<
[00:00:50.129]rec.time=17
[00:00:50.129]rec-left.time=235787
[2026-09-03 09:19:38.992]# RECV ASCII/102 <<<
[00:00:50.590][RT_CTS_PROBE] end frame=112 waited=1001ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:39.664]# RECV ASCII/115 <<<
[00:00:51.258][RT_CTS_PROBE] begin frame=128 pcm=163840B stream=12315ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:40.662]# RECV ASCII/102 <<<
[00:00:52.260][RT_CTS_PROBE] end frame=128 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:40.943]# RECV ASCII/122 <<<
[00:00:52.539][clock-manager]cpu0: 3% cpu1: 26% jlstream: 25% curr_clk:128000000 min_clk:128000000 det_clk:128000000, 1
[2026-09-03 09:19:41.319]# RECV ASCII/115 <<<
[00:00:52.918][RT_CTS_PROBE] begin frame=144 pcm=184320B stream=13975ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:42.316]# RECV ASCII/102 <<<
[00:00:53.920][RT_CTS_PROBE] end frame=144 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:42.927]# RECV ASCII/63 <<<
[00:00:54.530]rec.time=22
[00:00:54.530]rec-left.time=235782
[2026-09-03 09:19:42.973]# RECV ASCII/114 <<<
[00:00:54.579][RT_CTS_PROBE] begin frame=160 pcm=204800B stream=15636ms buffered=512B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:43.984]# RECV ASCII/102 <<<
[00:00:55.580][RT_CTS_PROBE] end frame=160 waited=1001ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:44.652]# RECV ASCII/115 <<<
[00:00:56.248][RT_CTS_PROBE] begin frame=176 pcm=225280B stream=17305ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:44.933]# RECV ASCII/123 <<<
[00:00:56.539][clock-manager]cpu0: 4% cpu1: 27% jlstream: 25% curr_clk:128000000 min_clk:128000000 dest_clk:128000000, 1
[2026-09-03 09:19:45.655]# RECV ASCII/102 <<<
[00:00:57.250][RT_CTS_PROBE] end frame=176 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:46.311]# RECV ASCII/114 <<<
[00:00:57.909][RT_CTS_PROBE] begin frame=192 pcm=245760B stream=18965ms buffered=512B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:47.322]# RECV ASCII/165 <<<
[00:00:58.910][RT_CTS_PROBE] end frame=192 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[00:00:58.929]rec.time=26
[00:00:58.929]rec-left.time=235778
[2026-09-03 09:19:47.975]# RECV ASCII/115 <<<
[00:00:59.579][RT_CTS_PROBE] begin frame=208 pcm=266240B stream=20636ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:48.938]# RECV ASCII/123 <<<
[00:01:00.540][clock-manager]cpu0: 5% cpu1: 27% jlstream: 25% curr_clk:128000000 min_clk:128000000 dest_clk:128000000, 1
[2026-09-03 09:19:48.984]# RECV ASCII/102 <<<
[00:01:00.580][RT_CTS_PROBE] end frame=208 waited=1001ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:49.640]# RECV ASCII/115 <<<
[00:01:01.238][RT_CTS_PROBE] begin frame=224 pcm=286720B stream=22295ms buffered=1024B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:50.635]# RECV ASCII/102 <<<
[00:01:02.240][RT_CTS_PROBE] end frame=224 waited=1002ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
[2026-09-03 09:19:51.306]# RECV ASCII/113 <<<
[00:01:02.899][RT_CTS_PROBE] begin frame=240pcm=307200B stream=23956ms buffered=512B cts=0 tx_idle=1 gap=1000ms
[2026-09-03 09:19:51.729]# RECV ASCII/63 <<<
[00:01:03.329]rec.time=30
[00:01:03.329]rec-left.time=235774
[2026-09-03 09:19:52.290]# RECV ASCII/102 <<<
[00:01:03.900][RT_CTS_PROBE] end frame=240 waited=1001ms dropped=32768B cts=0 cts_high=0ms tx_idle=1
