求分析一下EC200A的问题
EC200A无法响应所有AT指令,这是在电脑上用串口抓取的开机日志,请求技术人员帮忙分析一下原因。
[16:36:24.254]收←◆PI2C init done
PMIC init done
Finish loading TIM from: 0x0000001B
Init DDR: PASS
Load Image 0x4F424D49 : PASS
Verify Image:
[16:36:24.424]收←◆PASS
Xfer to OBM
GuilinLite: PMIC ID: 0x18
0xE9 = 0x5a
+Hot power up
This is SPI Nor 8M…
start…
NezhaC/Falcon MIFI
, Nov 11 2024 - 10:24:43
PMIC REG:0x00,0x01,0x10,0x13,0x14,0x18,0xE2,0xE5,0xE6,0xE2
PMIC VAL:0x18,0x02,0x02,0x00,0x00,0x00,0xF1,0x02,0x02,0xF1
PMICType 0x34 power_up_flag 1 quec_download_mode 0
power_up_flag: 1,1
emac_set_io_power_domain: init GMAC_IO_REG 0x85
emac_set_io_power_domain: after set GMAC_IO_REG 0x81
NO Production Mode
FlashNumber: 0x1b
Bus clock: 13MHz, QSPI CLK: 0x5b
use_intr 0, en_tx_dma 1, use_xip 1
SPI-NOR: XM25QU64C is found in table
SPI-NOR: mfr_id: 0x20, dev_id: 0x4117
Bus clock: 104MHz, QSPI CLK: 0x1db
QE(bit9) already set to 1
Rx_pins 4, Tx_pins 4, Read_op 11, write_op 19
AHB data transfer size: 128
XIP Read mode enabled
Fixed LUT bit-map: 0x1fc
pFlashP->NumBlocks: 128
[OTA] TR069_Addr 00760000
Tr069 Config Init Done
Allow to boot up
falcon_set_fbp:reserved_start_addr[0x0],reserved_end_addr[0x50ffff]
qspi_nor_find_match_fbp_type:find match fbp type is 12, protect area=0x0~0x3fffff
qspi_nor_set_flash_block_protect:read status1=0x0, status2=0x2; protect_type=0xc.
qspi_nor_set_flash_block_protect:update status1=0x38, status2=0x2.
qspi_nor_set_flash_block_protect:read after update, status1=0x38,status2=0x2.
qspi_nor_set_flash_block_protect:fbp valid.
[16:36:24.615]收←◆[Quec][Flash]:Abnormal Erasedblock not found(i=320)
ota_entry
ota ffffffff ffffffff
[OTA]No need to upgrade
LoadLogoImages
[OBM] ImageID 54494d48
[OBM] ImageID 52424c52
[OBM] ImageID 52424c49
[OBM] ImageID 4c4f474f
[16:36:24.675]收←◆logo compressed magic: 0x8000005d
logo magic:0xbabe5f5f, entry point: 0x6e402a4,load addr: 0x6e40000, header file size:0x1a0
lzma cpmpressed image
start lzma decompress logo
[LOGO] load header info from flash to psram
decompress logo from flash to psram
src_addr:[0x70001a0],src_len:[0xfe60],dst_addr:[0x6e401a0], logo in flash type:1
LZMA_Decompress start here…
0x00000000
0x00000000
0x0000006f
0x00006fd8
0x006fd8e0
[16:36:25.448]收←◆LZMA_Decompress() : good!
ret[0] inLen=[0xfe60], outLen=[0x10c28]
[OBM] TIM_Address d1000000
[OBM] partitionOffset[00000000]
OBM JUMP TO LOGO at 0x6e402a4
LOGO START
ver:20240304_db
[LOGO]OBM set TIM_Address[d1000000]
[LOGO] set PartitionOffset[00000000]
UartType,[00000031]
PmicType,[00000034]
ProjectType,[00000030]
ChargeStatus,[00000030]
OledStatus,[00000030]
PPEnable,[00000001]
PMIC ID: 0x18
Cold power up
OBM set flash type NOR
Bus clock: 13MHz QSPI_CLK_RES_CTRL: 0x5b
use_intr=0 en_tx_dma=0 use_xip=1
Bus clock: 104MHz QSPI_CLK_RES_CTRL: 0x1db
falcon_set_fbp:reserved_start_addr[0x0],reserved_end_addr[0x20000]
qspi_nor_find_match_fbp_type:find match fbp type is 7, protect area=0x0~0x1ffff
qspi_nor_set_flash_block_protect:read status1=0x0, status2=0x2; protect_type=0x7.
qspi_nor_set_flash_block_protect:update status1=0x24, status2=0x2.
qspi_nor_set_flash_block_protect:read after update, status1=0x24,status2=0x2.
Flash Init Done
sctlr_get value[00e50878]
CORTEX_MPU_Region_Init
sctlr_get value[00e5187d]
GuiLinLite Buck1 active voltage: 0x98
cpcore → 624M
AXI → 208M
DDR → 1066M
LWG/LTG switch flag 0x0
Select to 3Mode LWG
NumImages 9 ImageID 54494d48
NumImages 9 ImageID 52424c52
CRC check OK with flash address 0x30000
NumImages 9 ImageID 52424c49
CRC check OK with flash address 0x20000
MRD FlashAddress Passed to CP: 0x20000, pMRD_valid 0xd1000098
NumImages 9 ImageID 4c4f474f
NumImages 9 ImageID 4f534c4f
FlashEntryAddr[00050000],LoadAddr[06000000]
[16:36:25.746]收←◆[CODE_PS] decompress from [0x07002000] to [0x06002000]
[16:36:26.068]收←◆[CODEPSB] decompress from [0x0706f000] to [0x060e2000]
[16:36:26.325]收←◆[CODEPSC] decompress from [0x070c7000] to [0x061e2000]
[16:36:26.668]收←◆[CODEPSD] decompress from [0x0713a000] to [0x062c2000]
[16:36:26.997]收←◆[CODEPSE] decompress from [0x071aa000] to [0x063c2000]
[16:36:27.316]收←◆[CODE_AP] decompress from [0x07217000] to [0x064a2000]
[16:36:27.667]收←◆[CODE_NT] decompress from [0x07290000] to [0x065a2000]
[16:36:28.049]收←◆[CODE_PL] decompress from [0x07312000] to [0x066c2000]
[16:36:28.211]收←◆[CODEPLB] decompress from [0x0734a000] to [0x067c2000]
[16:36:28.590]收←◆[REMAIN_] decompress from [0x073bc000] to [0x068e4af0]
[16:36:28.655]收←◆NumImages 9 ImageID 47524249
FlashEntryAddr[00430000],LoadAddr[07e40000]
[DSP]decompress from [0x07001000] to [0x07e40000]
[16:36:28.912]收←◆[DSP]decompress result[[0]],inLen [0x0004c3e9],outLen [0x000e0000]
[DSP]decompress from [0x0704e000] to [0x07f20000]
[16:36:29.119]收←◆[DSP]decompress result[[0]],inLen [0x00044fe8],outLen [0x00070000]
[DSP]decompress from [0x07093000] to [0x07f90000]
[16:36:29.201]收←◆[DSP]decompress result[[0]],inLen [0x00019073],outLen [0x00030000]
[DSP]decompress from [0x070ad000] to [0x07fc0000]
[16:36:29.261]收←◆[DSP]decompress result[[0]],inLen [0x00012c1c],outLen [0x00020000]
[DSP]decompress from [0x070c0000] to [0x07fe0000]
[DSP]decompress result[[0]],inLen [0x00005ac9],outLen [0x00010000]
[DSP]decompress from [0x070c6000] to [0x07ff0000]
[DSP]decompress result[[0]],inLen [0x0000006c],outLen [0x00010000]
NumImages 9 ImageID 5246424e
FlashEntryAddr[00500000],LoadAddr[07a00000]
FLAG1:1000005D,FLAG2:800000,num=0,rf1_size:0,rf2_size:1006657536
CAN NOT FIND MULT RF
Retval 0x0
NumImages 9 ImageID 55505445
Primary/Backup MRD are both OK
cpcore → 208M
DDR → 533M
LOGO END
** LOGO DONE JUMP TO CP IMAGE
** PC : 0x6000000
[16:36:29.683]收←◆b buadrate=0
b Board info: 128 116 51 860641095 @ 1.057.067_#98918 Mar 4 2025 12:07:15
c last thread: ComPM_LP
c Silent Reset: 0 0 0
d ======= CIU register =======
d 0xd4282d00: 0x373
d 0xd4282d04: 0x3fb57
e 0xd4282d08: 0x53503e
e 0xd4282d38: 0xce240b06
f 0xd4282d3c: 0x8607dbd1
f 0xd4282d40: 0x500ca143
10 0xd4282d44: 0x0
10 0xd4282d48: 0x0
10 0xd4282d4c: 0x0
11 PMIC ID: 0x18
11 PMIC type: Guilin_Lite(PM803)
12 falcon_set_fbp:reserved_start_addr[0x0],reserved_end_addr[0x50ffff]
13 qspi_nor_find_match_fbp_type:find match fbp type is 12, protect area=0x0~0x3fffff
14 qspi_nor_set_flash_block_protect:read status1=0x0, status2=0x2; protect_type=0xc.
16 qspi_nor_set_flash_block_protect:update status1=0x38, status2=0x2.
17 qspi_nor_set_flash_block_protect:read after update, status1=0x38,status2=0x2.
18 qspi_nor_set_flash_block_protect:fbp valid.
[16:36:29.782]收←◆1e Start to UnPack RD NVM
22 psm config: 0x20 079a0000 7929856 4
23 psm chk:0701ac40 0x5a5a5a5a,0xa5a5a5a5 0x2d4
24 psm chk:0701aca0 0x5a5a5a5a,0xa5a5a5a5 0x0
24 psm chk:0701ad00 0x5a5a5a5a,0xa5a5a5a5 0x0
25 psm chk:0701ad60 0x5a5a5a5a,0xffffffff 0xff00ff00
26 psm chk result:1 0
26 psm file info:0 0 0
27 psm file info:1 1 1
27 psm file info:2 2 2
28 PMIC_GuilinLite_Configure_Marvell_LMIFI_V5R0 Enter.
2a AIB_MMC1_IO_REG 0x81
2a PMIC_GuilinLite_Configure_Marvell_LMIFI_V5R0 Exit.
2b quec_set_emac_domain: init GMAC_IO_REG 0x81
2b quec_set_emac_domain: after set GMAC_IO_REG 0x85
2f FDI_fclose_psm: done
2f ===sd card init===
30 ==sdcard pin config start==
30 ==sdcard detect pin config==
31 sdcard detect:0xd0c0
31 ==sdcard pin config end==
32 SDCARD:SD0_HOST_PMU_AXI_CLOCK=119
32 ==sdcard set power==
34 sdcard set power f
34 sdcard set ctrl 0
34 SDCARD:SD_CLOCK_CTRL_offset=4047
35 SD_InsertRemove_Task wait
36 sdcard:version:2
36 sdcard:SDHCI_CAPABILITIES1=0x80
36 sdcard:SDHCI_CAPABILITIES2=0x25fc
37 sdcard:SDHCI_CAPABILITIES3=0x2f77
37 sdcard:SDHCI_CAPABILITIES4=0x0
38 sdcard detecting start.
38 Send CMD0
39 CMD0 Done!
39 Send CMD8
39 sdcard_isr error interrupt 0,1
3a Error Invoke CMD8, version1.0 or No SD inserted!
3a send ACMD41
3a sdcard_isr error interrupt 0,1
3b Error Invoke CMD55
3b sdcard init error!!!
3b eeHandlerPhase2Init
3b quec_usb_pax_sulog flag read
3c quec_usb_pax_sulog read fail
3d bank3 PMUA_AES_CLK_RES_CTRL 0
3d bank3 223_192 7a910000
3f usb_device_init,usb_driver=0x12
3f UsbDgbCtrl_TaskCB, enter
3f usb phy pll status 60e9
3f disable RUN BIT
3f Usb net mac address: 2-c-29-a3-9b-6d
3f USB2MgrUpdateDescriptor, desc= 69
40 Usb drv=0x12 mode=0 desc=69 VBUS LOW
42 TSEN:Tsensor: Initilized.
42 DdrClkSwitchBypass 0, DDR1066_switch_flag 1, DDR1066_switch_running 1
46 tsen–> Current temperature: 33 Celsius
46 No SD, disable SD log
46 Start to UnPack Reliable data
47 RD file: audio_voice_calibration.nvm
49 RD file: DipChannelCfg.nvm
49 RD file: TTPCom_NRAM2_CUSTOMIZATION_DATA.gki
4a Start to UnPack Factory data
4b imei: 864790082766610
4b WIFI MACADDR:42,43,3a,32,41,3a
4c RD file: aplp_rf_calibration.nvm
4f RD file: LteCalData.nvm
4f RD file: Dcxo_Calibration.nvm
50 SN: P1825HG0A0020470P
50 factory is not change,not record again
53 utlShowAtParams,ATP7 >>>>
53 S[0]:0
53 S[1]:0
54 S[2]:43
54 S[3]:13
54 S[4]:10
54 S[5]:8
54 S[6]:2
55 S[7]:0
55 S[8]:2
55 S[9]:6
55 S[10]:7
55 echo_text:1
56 verbose_results:1
56 suppress_results:0
56 include_connect_text:0
57 detect_dial_tone:0
57 detect_busy_signal:0
58 dialing_mode:0
58 raw_framing:3
58 raw_parity:3
59 report_localrate:0
59 dce_by_dte:2
59 dte_by_dce:2
5a dcd_always_on:0
5a ignore_dtr:0
5a drop_call_on_dtr_loss:0
5b dsr_mode:0
5b <<<<<<<utlShowAtParams
5f loadPSRegOptionSetting: enter
61 initAtPara: enter
61 Not Production Mode
[16:36:30.537]收←◆af ######## quec_system_init ok ########
af EC200ACNV1LAR02A06M08 V01
af Application Start…
[16:36:30.635]收←◆c2 marvin, read sim_poll_cfg fail sim_poll_cfg = 0
c2 quec_get_sim_poll_cfg() = 0
c3 res_buf=+MEDCR:82,0
[16:36:31.551]收←◆176 ATCmdSvrRdy
[16:36:31.645]收←◆189 quec_init failed!
[16:36:42.777]收←◆a1e PM PWD
您使用的是OpenCPU方案吗?请具体描述一下问题场景。
